Old 07-30-2023, 04:00 PM   #1
don t. - 72gmc
Starters
1970 GMC BB TH400. C2500 if it matters.
It's been sitting for a good many years. Decided I'd clean up the electrical connections on the starter while I was down that way. Ran into a few issues.
1 - All 3 wires near the starter should be R&Red due to dry rot.
Batt cable is a no brainer. The yellow wire will not be replaced as I have HEI. Anyone know the gauge of the purple wire? Looks like 14ga to me but??? Just for grins, if I was replacing the yellow wire, what gauge?
2 - All 3 connections ended up rotating the stud of the solenoid.
Time for a new solenoid or would you just snug them back down?
3 - Following the purple/yellow wire back to the firewall was covered in tape. Aint no easy way to get tape in many areas along the path.
Suggestions appreciated.
Thanks much...Don.
don t. - 72gmc is offline   Reply With Quote
Old 07-30-2023, 06:34 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Starters
Purple is 12 ga, yellow is 20. Here's a wiring diagram.
~Steven
Simi Valley, CA
Old 07-31-2023, 02:13 PM   #3
don t. - 72gmc
Re: Starters
Thank you...Don.
