Originally Posted by red450ih
Put a 14 Semi float in place of an eaton? ![EEK!](http://67-72chevytrucks.com/vboard/images/smilies/eek.gif) I would keep the eaton in the rear. There is noway I would pull it to put a 14 bolt Semi-floater in it's place. If the eaton ever gave up on me I would replace it with a 14 bolt Full Floater.
The ring gear diameters are as follows:
14 semi float 9.5 inches
14 Full Float 10.5 inches
Eaton Full Float 12.25 inches
Keith
Actually, the Eaton he is probably referring to has a 10.5" ring gear. The 12.25" ring gear axle was an option in one ton trucks, and is called the H110. The diff cover of this axle was welded on instead of bolted on.
But I agree, I would keep the Eaton too. Actually, I am going to swap out my 30 spline dana 60 for one with a detroit locker.
