Old 08-13-2004, 04:49 PM   #1
skokie
skokie's Avatar
Harmonic Balancer Bolt
Does the harmonic balancer go on the outside of both crank pulleys or on the pulley that is on the back facing the balancer itself? This is for a short waer pump setup and its a 68.
skokie is offline   Reply With Quote
Old 08-13-2004, 05:03 PM   #2
grayw0lf
I don't know about your specific setup, but on almost any engine the harmonic balancer goes on after the timing cover. The crank pulley then mounts on/over to the harmonic balancer.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 08-13-2004, 05:13 PM   #3
skokie
skokie's Avatar
Looking at the pics which one is correct? 1 or 2.
Old 08-13-2004, 05:40 PM   #4
LONGHAIR
2 is correct.........The washer should be holding the pulley away from the balancer in pic 1, not good.
LONGHAIR is offline   Reply With Quote
Old 08-13-2004, 06:41 PM   #5
ScottH
ScottH's Avatar
Longhair, r u sure about this? I'm only a backyard mechanic, but I always thought the purpose of the balancer bolt was to secure the balancer. The three bolts on the outside secure the pulley. But I've been wrong before.....
ScottH is offline   Reply With Quote
Old 08-13-2004, 08:12 PM   #6
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
i would have to vote with longhair on this one
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 08-13-2004, 11:03 PM   #7
crazy longhorn
Fabricate till you "puke"
Longhair is d@mn sure about that, & so am I crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 08-14-2004, 12:07 AM   #8
mr402
Maybe on a small block but on the big block pulley there is a recessed area on the balancer just for the washer. This way the washer face sits flush with the front side of the pulley. If you try putting the washer and bolt over the pulley you'll bend it. Here's a picture from a cut away in How to Hot Rod your Big Block Chevy. Page 3. Now I can't say for 100% the same carries over to a small block but it sure seems to me it would.
mr402 is offline   Reply With Quote
Old 08-14-2004, 02:19 AM   #9
Budweis
Geared for Collision
Budweis's Avatar
longhair is right and pic 2 is right least thats how its been on 10+ chevy 350's ive had
MEMBER OF THE 4 WHEEL DISK BRAKE CLUB
1970 C/K20 3/4 Ton
1996 Collectors Edition Corvette
1977 Corvette Coupe
Budweis is offline   Reply With Quote
Old 08-15-2004, 01:57 AM   #10
Bowed
my 454's are like #1 and the pic mr402 showed . Also the center hole on my pulleys are much larger then the pulley in the pics .
Bowed is offline   Reply With Quote
Old 08-15-2004, 02:14 AM   #11
skokie
skokie's Avatar
Well after talking to a few people on the board here and a few shops in the area I decided to go with pic #2. Thanks for all of the help. I appreciate it.
