08-11-2004, 05:45 AM | #1 |
1967 power steering kit?
OK guys it's time to do this!!!!! Can someone tell me who makes or sells a power steering conversion kit for my 1967 2wd lwb. And I know some of you have done this so any thing you can share would be a big help.I gotta get this done !!!!!!!!!!!!!!!!!!!!!!
08-11-2004, 06:55 AM | #2 |
Ps
I think the true '67 PS had a ram system, similar to the corvette. My '67 has a transplanted pump & box from a later year. I have a complete changover "kit" from a '72 for $115 shipped if you're interested......Zoomy
08-11-2004, 10:43 AM | #3 |
Ozark Tim
The last response is correct. The original power steering system on 67 pick up's was unique to that year only. The system was almost identical to the slave cylinder style power steering on corvettes up till 83 or so. I have actually rebuilt 67 slave cylinders with corvette rebuild kits, but the esiest retro would be to go with 68-72 style pump & gear.
08-11-2004, 11:13 PM | #4 |
Sisyphus was my mentor!
I have the same strong-arm steering & I too have been looking at this problem. Check out these links:
http://67-72chevytrucks.com/vboard/s...d.php3?t=94960 http://67-72chevytrucks.com/vboard/s....php3?t=100158
passthebuck #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
08-11-2004, 11:16 PM | #5 |
its all about the +6 inches
Didn't 68 have the ram set up also?
08-12-2004, 03:48 AM | #6 | |
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
08-14-2004, 05:22 PM | #7 |
I had a '67 K/10 4x4 Suburban that I tried putting a '69 PS set up on. Ran into big problems. Steering geometry was AFU: I had to start my left turns from the middle lane or I'd wind up on the sidewalk. Right turns were a little easier, but it was like docking the Queen Mary to parralel park. Also the PS gear was really strong and I broke a couple of 1/2" frame mounting bolts when there was more force than travel. Also shifted spring perch on drivers side. Didn't know about the Corvette trick at the time. Finally went back to Armstrong System, but since we had to cut and weld the original draglink, the geometry was never the same. Bought a '75 Dana 44 front axle so I could switch to later style PS system and also have power disc brakes. Project is down awaiting more cash.
08-14-2004, 11:03 PM | #8 |
'68OrangeSunshine, the problem you most likely had was there was supposed to be a dimple in the frame for the later power steering box, and yours was probably installed with spacers or shims to make it bolt up. This places center, a little off center on the gear, and causes all kinds of problems. It also sounds like you used a later box with the variable rate gear which would make things worse.
08-15-2004, 02:37 AM | #9 |
The gear box came off a '69 GMC c/1500 panel that a guy was parting out. The pump assy was a later model as they were reputedly more reliable. [Of course just because it came off a '69 doesn't mean it's actually that vintage.] We did use a lot of shims. This occurred a couple of years before I found this board. Which has become an addiction in itself. I just know that '67 is a trouble year for PS, especially in a 4x4.
