Finish the'71..or bust!
How Many?? 1969 LWB w/396 BB and A/C...
I went to look at yet another truck today.
It is a 1969 LWB CST/10 that came from the factory with a 396 and AC. Also has power steering. (no power brakes). Anothe rneat thing about the truck is that it had shoulder harness seatbelts installed. I don't know if they are factory units but the 'red' color matched the rest of the interior...and the 'fading' looked 'correct'...LOL. Anybody got a pic of the original seatbelts in this configuration (especially the plastic box-thingy at the floor)???? It originally had a '3 on the tree'...but now has a 400 turbo trans....with a floor-mounted shifter. Looks like a typical 4-speed-as it still has the clutch pedal mounted. ![]() Not sure if the 396 is the 'original motor'...but the current owner believes it is. He even had most of the original sales paperwork and even had the Protect-O-Plate. Over all it was a pretty decent truck. Steel floor was even straight. Only real issue was the ol' battery problem...needs passenger inner and outer fenders and radiator cross support. Otherwise the old truck was pretty straight! My question is.....are '69 Big Blocks w/ Air uncommon? If it was a SWB I would have to jump on it regardless.....but still, I could use a decent 'work' truck. Also, would it be a big PITA to add a power brake booster to this truck? It still has it's original 6-lugs w/drums on all 4 corners. Thanks for any info! ![]() Last edited by SLS; 08-14-2004 at 05:59 PM. |
#2 | |
its all about the +6 inches
Sounds like a cool truck. I don't think they were so much produced in low numbers, but there sure seems to be a shortage of them these days.
The seat belts are probably not original. Quote:
The data sticker on the inside of the glovebox door should give you the trucks options. The protecto plate will help you search out original owners and such.
Thanks for the info guys!
The seatbelt/shoulder belt system must not be original as it is a 'loop' tye of setup. It has a retractor gizmo that is mounted to the floor next to the seat and the belt goes up to a oval-shaped ring on the pillar...one buckle....continous loop. |
