Old 08-15-2004, 11:32 AM   #1
71swb4x4
71swb4x4's Avatar
Which one is #1 on an HEI
I have finally started putting my TPI on my truck. Which one on the HEI is #1? I included a picture, along with the one that I think is #1. I would rather find out I am wrong now than when I try to start my truck so hlep me out
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 08-15-2004, 11:35 AM   #2
71swb4x4
71swb4x4's Avatar
Do you go clockwise or counterclockwise?
Old 08-15-2004, 12:13 PM   #3
gonebad2
Merciless Butcher
gonebad2's Avatar
The one you circled is ok to use as number one. Your firing order on the distributor goes clockwise.
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 08-15-2004, 12:51 PM   #4
71swb4x4
71swb4x4's Avatar
Thank You!!
What a question from someone doing a TPI swap huh, I was pretty sure that was the way it went but its been a long time since I have pulled my plug wires.
Old 08-15-2004, 05:22 PM   #5
junkyardjohn
junkyardjohn's Avatar
I USUALLY USE THE TERMINAL CIRCLED, OR THE ONE DIRECTLY TO THE RIGHT OF IT. IT REALLY DOESN'T MATTER WITCH TERMINAL YOU START WITH, OR CALL #1 AS LONG AS YOU INSTALL ALL THE OTHER WIRES IN THE CORESPONDING FIRING ORDER, & THE TERMINAL YOU ARE CALLING #1 IS POINTING AT THE # 1 CYL WHEN IT IS AT T.D.C. (THE DIST. DOESN'T KNOW THE DIFFERENCE) JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 08-15-2004, 05:30 PM   #6
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
junkyardjohn is right, any terminal is # 1 as long as you put the wires in the correct firing order. I have been through this before too.
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 08-15-2004, 05:45 PM   #7
robertwb
TPI will fit with a large cap HEI?
1972 LWB 4x4
1970 LWB 2wd
1971 chevelle
1972 datsun PL-521/nissan
robertwb is offline   Reply With Quote
Old 08-15-2004, 05:48 PM   #8
neonlarry
neonlarry's Avatar
Yes, they did not go to small cap until 1988.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 08-15-2004, 10:25 PM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Like was said, number one is where you make it. But, technically GM did it where you have the circled terminal. Factory HEI's had a ring around the plug wires that was labeled as to which cylinder went where.
Insert Tx Firefighter (TM) picture of said ring....
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 08-16-2004, 08:19 AM   #10
Blue Beard
Blue Beard's Avatar
Now you've all put a question in my mind....
Seems like some of the diagrams I've seen had the #1 on the front right side of the cap.
Either that or I had too much too drink when looking at it.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 08-17-2004, 08:18 AM   #11
GMC AMI
GMC AMI's Avatar
Engine has to be top dead center on # 1 then the rotor has to be on the terminal you pick as the # 1 to start firing order.
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
