Old 08-01-2023, 02:00 PM   #4076
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Re: What did you do to your truck today.The 3rd chapter
Originally Posted by 3757chevy View Post
I got them on UPS yesterday.
that's cool, I missed when you first posted you found them - thanks!
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
Old 08-01-2023, 04:12 PM   #4077
HO455
HO455's Avatar
Originally Posted by Rich72C10 View Post
Looks like I finally got my rear end leak fixed after using JB-Weld on a plug. What a PITA to have a leak on these plugs! Also changed out my starter and I think (hope) I am golden now.
It's good to know I'm not the only one who has had a leaking plug weld.
RIP Bob Parks.
Old 08-01-2023, 06:09 PM   #4078
Steeveedee
Who Changed This?
Steeveedee's Avatar
Unboxed my new front grille and admired it. Kind of a cheap-looking stamping. Oh, well, at least it's shiny.
~Steven
Simi Valley, CA
Old 08-01-2023, 06:28 PM   #4079
body bolt
I was able to source a new clutch for my 4 seizens #58098 A/C compressor from UAC and, for anyone else who ever needs one, the part number is CL 1654C. I installed it yesterday but saved installing the belt for this cool morning. I had thought a bit about why the previous clutch failed and suspect low voltage at idle caused the clutch to slip and burn everything up as it failed just after sitting at a long red light. I added a fused Bosch relay to feed the clutch coil directly from the battery which should cure/prevent that.
body bolt is offline   Reply With Quote
Old 08-01-2023, 07:04 PM   #4080
72c20customcamper
72c20customcamper's Avatar
Got stuck with the 72 . I have been pushing not replacing the flex plate . Today the dreaded whine of the bendix spinning on the ring gear . I managed to get a tire iron into the gear and spun the flex plate about 25 degrees . Truck started right up but with the usual grinding noise
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 08-01-2023, 09:17 PM   #4081
samkost
samkost's Avatar
My truck cover was delivered to keep the C10 from getting dusty.
Fitment is very good with added mirror pockets.
No cut out for the aerial though, so I just unscrew the antenna.
samkost is offline   Reply With Quote
Old 08-02-2023, 01:03 AM   #4082
3757chevy
3757chevy's Avatar
You bet, glad I could help.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 08-02-2023, 08:34 PM   #4083
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
236 miles on my truck so I did a oil service. Sort of kidding, the engine is low mile but not THAT LOW, but I did do a few things to it, and it sat six years before the 236 miles. New oil sat with it for 1/2 that, so kind of figured it was due and how nice to do an oil change on a restoration.
I lubed the suspension and steering as well, they were due for certain. Can't get much grease into new parts, but after some miles they'll take it.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 08-03-2023, 07:22 AM   #4084
don t. - 72gmc
New starter, pos batt cable, purple(now blue) installed. Have HEI, no yellow wire.
Motor oil and filter.
Filled radiator.
Filled tranny.
Cleaned, gapped, odd side plugs. All plugs will get R&Red once it gets running.
Need to get a new Skip White dizzy cap and rotor.
To do list is getting shorter.
Im happy...Don.
don t. - 72gmc is offline   Reply With Quote
Old 08-03-2023, 05:51 PM   #4085
72c20customcamper
Well the truck is christened. First time water of any kind has touched it since I finished it .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-03-2023, 06:07 PM   #4086
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Changed oil & filter after doing the first 500 miles with the break in oil in the truck.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 08-03-2023, 07:43 PM   #4087
Sheepdip
Sheepdip's Avatar
I like that Dual Snorkel Air Cleaner!
Sheepdip is offline   Reply With Quote
Old 08-03-2023, 09:43 PM   #4088
Steeveedee
Who Changed This?
Steeveedee's Avatar
I want one of those, myself! It is indeed in my future.
~Steven
Simi Valley, CA
Old 08-03-2023, 10:27 PM   #4089
Already Gone
Bought it from Rock Auto a few years ago. Application is for a 1972 Z28 Camaro and it fits my Q Jet perfectly.
Old 08-03-2023, 10:41 PM   #4090
Steeveedee
Who Changed This?
Steeveedee's Avatar
Does it have the heat tube valve on the left snorkel?
~Steven
Simi Valley, CA
Old 08-03-2023, 11:05 PM   #4091
Already Gone
Nope, you probably need that hooked up in California.
Old 08-04-2023, 09:41 AM   #4092
Steeveedee
Who Changed This?
Steeveedee's Avatar
Probably, but I'll buy one like yours anyway. The heat tube has never been on the truck in the 42 years that I've known of it.
~Steven
Simi Valley, CA
Old 08-05-2023, 09:27 AM   #4093
un4gvn!
un4gvn!'s Avatar
I finally got my interior finished. Took me a while, but got-r-done. Now I can take the grand kids for a ride.
un4gvn! is offline   Reply With Quote
Old 08-05-2023, 09:35 AM   #4094
68bowtie
68bowtie's Avatar
That looks fantastic!
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce
Thank you all so far you are angels!!
68bowtie is online now   Reply With Quote
Old 08-07-2023, 09:55 PM   #4095
LockDoc
The Older Generation
LockDoc's Avatar
Had some funny noises coming from the drive train on the '72 Dually. I thought it was a front wheel bearing. It's hard for me to tell where noises like that are coming from with my bad hearing. I had an ex-mechanic friend of mine go for a ride with me to see what he thought about it. He said he thought I had a flat tire on the passengers side rear and I had a clicking noise coming from the same area. The outside dual tire was indeed low on air so I aired it up and checked the inside tire. It was completely flat. I thought what the heck is going on here.... I got to checking closer and both of the valve stems were cracked down by the rim. I removed the wheels and tires and took them to my local tire shop and had them put new valve stems in them. The guy that fixed them said it looked like I picked something up between the duals and it rattled around inside enough to break both of the valve stems. Just my luck. There wasn't anything there when I took them off.
When I had the wheels off I turned the drum and I could hear something rattling around inside the drum. OK, now I'm going to have to pull the axle and hub/drum assembly off to see what that is. I found that the adjuster spring had broken and the adjuster had dropped out of place and broke some of the other parts and pieces. Luckily I had a pair of new shoes for it so I just had to scrounge up some small parts. I didn't have an H072 adjuster assembly or the spring for it. All of mine are too small so I will have to see if I can find those on the parts board.
Seems like it is always something. I guess I'm lucky it didn't lock up on me....
Leon
Old 08-07-2023, 10:13 PM   #4096
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
It sounds like you are pretty lucky to me. Nice that you found it.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 08-08-2023, 03:18 PM   #4097
72c20customcamper
NOS Studebaker tailpipe extension looks good on a Chevy
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-08-2023, 03:58 PM   #4098
LNP
I have the same cleaner except mine came with a chrome lid.
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
Old 08-08-2023, 04:08 PM   #4099
LockDoc
LockDoc's Avatar
Thanks Dale.
I Have it all put back together except for the adjuster and spring.
LockDoc
Leon
Old 08-08-2023, 05:03 PM   #4100
Steeveedee
Who Changed This?
Steeveedee's Avatar
^ Lucky nothing worse happened, Leon!
Put the new grille in my truck over the weekend. Old and new, for comparison. Much better! Next up is paint and install the headlight bezels. Thanks to @Richard for the insert!
~Steven
Simi Valley, CA
