#26 |
Re: Syclone Killer
Looks good! Keep up the good work!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#27 |
![]() Join Date: Nov 2018
Re: Syclone Killer
So no updates, mainly been messing with the Lincoln and working. But for any S 10 owners with fog lights this may interest you. ironically I found one switch the day after I ordered the other, but on with the point. The switch with the very nice bezel had cut wires, so I ordered an NOS switch for an Astro van and robbed the actual switch part and viola NOS s10 fog light switch. Atleast now o have a not so purdy spare that I’ll never need.
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
#28 |
Re: Syclone Killer
Sometimes when life is too busy even the smallest things feel like an accomplishment. Only update is I got the truck in the garage and now I have the correct rear end under it.
If anyone has ever tried to find a factory 4WD 3.73 axle you know it’s not too easy, bonus it’s a disc brake rear with aluminum calipers to match my blazer dual pistons up front.
#29 | |
Still plays with trucks
Re: Syclone Killer
I did something similar to your project using a Bravada as the donor inside and out. I made my S10 into an Oldsmobile Bravada appearing AWD truck with the upscale Olds leather interior. The plan was to turbo the 4.3 but I didn't get that far before I needed a bigger truck for work and it had to go in favor of my 1995 DRW K3500.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#30 | |
Re: Syclone Killer
#31 |
Re: Syclone Killer
Yes it’s been a while, between working 6 days a week, the cold, and upgraded the Lincoln to a 6speed auto, let’s just say I’ve had my hands full.
So anywho, for those that haven’t ever seen an LS7 clutch here ya go. The flywheel and clutch only go with each other as you can see there are raised pads for the pressure plate and speaking of, look at the thickness(mass) of the pressure plate. I didn’t have trans fluid laying around and it’s a lot easier to fill before installing so perhaps I’ll get that done tomorrow. I did get the LS2 intake put on, took it off the Lincoln where I was using adapters and put the correct Ls3 one on it so there is another thing that had to wait.
#32 |
Re: Syclone Killer
Sunbird cluster.
![]() Do you happen to recall the number of that GT? I've been halfheartedly documenting them and wouldn't mind adding that to the junked list. ![]()
Jay 2001 Pontiac Aztek GT |
#33 |
Re: Syclone Killer
Well technically not a sunbird cluster but they did start off as that. Redline is different.
#34 |
Re: Syclone Killer
SomeTimes I hate living so close to Summit, other times I love it. Picked up a set of scratch and dent special Corvette rotors and pads. Guess that means it’s getting the big brake treatment
#35 |
Re: Syclone Killer
Thanks!
#36 |
Re: Syclone Killer
No updates per say. I’ve been fiddling a little at night when it’s cooler. Putting the Lincoln on hold for a bit since all that’s left is paint Really.
Anyways decided this will be my third vehicle with hydroboost. Also acquired a ridetech 3 link for the rear suspension. So gotta back up a little before going forward. Kinda had no choice at $400 instead of retail at $1850. And was given a K&N kit for a 18 and newer Tahoe which will work great for my air intake
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com Last edited by Madkidd007; 08-06-2023 at 07:26 PM. |
#37 |
Re: Syclone Killer
I’ll just leave this here.
#38 |
Equal opportunity joke ofender
![]() Join Date: Oct 2011
Re: Syclone Killer
I don't see how it will help leaving it there. I would put it on the truck
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
#39 | |
Re: Syclone Killer
Proof of concept works, now I just need some 3/8 steel to make the adapters. 14” GT500 rotors with the stud holes opened up to 3/4”. And the hub bore size is within 1.5mm so I’m not worried about vibrations.
