Old 07-09-2023, 07:38 PM   #1
michael bustamante
michael bustamante's Avatar
Bad vibration...
So me and my daughter took the 67 GMC on its made in Cruise last night and we cannot get it above 30 miles an hour as there is a vibration as soon as it hits 30. I checked the driveline and the carrier bearing and those seem to be fine. Do you guys have any idea of what could be causing this in my 3/4 ton?
8/9/2023 ok update!!! i put on new wheels and tires.. still got the bad vibrations.. lifted the rear end in the air and my rr tire is moving a little wonky.. new tire, mounted balanced blah blah.... swapped tires and it still moves wonky. like a bent rim would but its not that. its a floating rear end, could the axle be bent and causing this? axle seal is not leaking. driveshafts look true when my daughter hits gas.. no play, carriewr bearing look s good.
Even with the rear end in the air it still vibrates the whole truck at about 25 mph... any ideas?
1967custom
michael bustamante is offline   Reply With Quote
Old 07-09-2023, 07:41 PM   #2
54blackhornet
54blackhornet's Avatar
Re: Bad vibration...
Sticking caliper ? It happen to me thought a wheel was loose.
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 07-09-2023, 07:42 PM   #3
Getter-Done
Getter-Done's Avatar
What is the condition of the wheels and tires?
If you have a place to safely jack up the rear axle and put it on jackstands.
That would eliminate some stuff.
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 07-09-2023, 07:57 PM   #4
michael bustamante
That's what I'm about to do now.. lift and check the rear end and the trans mount but yup you may be right about the sticking brakes too. (All drum)
1967custom
Old 07-09-2023, 08:45 PM   #5
RustyPile
RustyPile's Avatar
If it's been sitting in one spot for a while, check for flat spotted tires.
RustyPile is offline   Reply With Quote
Old 07-09-2023, 09:37 PM   #6
72c20customcamper
72c20customcamper's Avatar
My vibration was the rear ujoint at the pinion bad vibration at 35 and up
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 07-09-2023, 11:37 PM   #7
guyryan100
guyryan100's Avatar
Mine was old tires. I've read some interesting troubleshooting ideas on this site, including narrowing it down to front or rear based on whether the rearview mirror in the cab shakes, indicating front end problem, or you feel it in the seat, suggesting its the back end. Also whether it only shakes when you are accelerating which suggests an engine-related issue. I jacked up one rear wheel as a test and found no vibration with the rear wheels spinning, which eliminated transmission and driveshaft issues.
guyryan100 is offline   Reply With Quote
Old 07-10-2023, 09:09 AM   #8
Bigdav160
Bigdav160's Avatar
Driveshafts out of phase (is it even possible on a GM?). Frozen U-joint.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 07-10-2023, 09:39 AM   #9
michael bustamante
well the tires are shot (cracked up on the sid wall) but hold air.. been flat for at least 10 years. too bad as they were new too. drive shaft seems solid.. im going to jack up the rear end after work today
1967custom
Old 07-10-2023, 11:44 AM   #10
72c20customcamper
Umm tires ASAP dont move or pass go till you do . Tires that sit flat tend to crack all the way through the sidewall
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-10-2023, 11:58 AM   #11
michael bustamante
yup no more cruzes until i replace the rims and tires... but im still gonna check the rear end and make sure the brakes arent sticking
1967custom
Old 07-10-2023, 03:47 PM   #12
54blackhornet
I have doubts drum brakes could cause it, Disc brakes more likely.
71 C-20
07 Magnum RT AWD
Old 07-10-2023, 07:53 PM   #13
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
My first thought was an unbalanced wheel.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 08-09-2023, 11:29 PM   #14
michael bustamante
to the top.. please read the update.. need help! i cant drive my truck!
1967custom
Old 08-10-2023, 07:13 AM   #15
Bigdav160
Bigdav160's Avatar
That speed (30mph) is indicative of a driveline vibration, not tires
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 08-10-2023, 08:38 AM   #16
dmjlambert
dmjlambert's Avatar
It sounds like you might have found it. To confirm it, what I would probably do is jack up the right rear and remove the wheel, and put a straight edge such as a carpenter's square on the mounting surface of the axle and mark the floor with a pencil where the straight edge points. Then rotate the axle and repeat several times.
dmjlambert is online now   Reply With Quote
Old 08-10-2023, 09:14 AM   #17
NGN
NGN's Avatar
Maybe a motor mount collapsed. Trans mount also.
NGN is offline   Reply With Quote
Old 08-10-2023, 09:35 AM   #18
72c20customcamper
Pretty hard to bend a floating axle . If something is bent I would think the hub or axle tube to be bent since the axle itself doesn’t hold any weight the drum and hub do . I would look at the drum itself and check the bearings
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-10-2023, 02:56 PM   #19
body bolt
Perhaps some crud between the brake drum and the hub?
body bolt is offline   Reply With Quote
Old 08-10-2023, 03:22 PM   #20
michael bustamante
ok ill do this tonight and iull tear into the drums assy and make sure bearings are true as well. ive never worked on a floating axle before so wish me luck
1967custom
Old 08-10-2023, 06:00 PM   #21
RonWT
Active Member
RonWT's Avatar
check bellhousing bolts, check fan and all belts, check the U joints, flexplaate/flywheel?
RonWT is offline   Reply With Quote
Old 08-11-2023, 05:40 PM   #22
michael bustamante
All that looks good, took off the bell housing cover, nocracks in flywheel, all engine mounts are solid, ( no lifting on powerbrake) no play in u joints or the drive shaft and no wobble under acceleration
1967custom
Old 08-11-2023, 07:31 PM   #23
RonWT
Active Member
RonWT's Avatar
Pilot bearing?
Old 08-11-2023, 09:04 PM   #24
HO455
HO455's Avatar
From what I have understood you didn't have any vibration and then one day you did. Does the truck get driven regularly?
Then several weeks later you put new wheels and tires on and you still have the vibration. Were they new tires or a different pair of used tires?
My old 09 2500 Ram 4x4 tires would flat spot if I didn't drive the truck at least every other week. It would take 10 or more miles for the flat spots to work out every time it happened.
Did you replace the front tires as well?
Have you inspected the drive lines to see if one of the balancing weights has fallen off?
Try holding a straight edge to the drive lines and see if you can see a bend.
Did you check the yoke at the transmission for play? The same goes for the input shaft on the axle.
Does the vibration at 30 mph the same no matter what gear you are in?
RIP Bob Parks.
Old 08-11-2023, 10:27 PM   #25
tdangle
tdangle's Avatar
I had a bad vibration that came in at about 40 MPH. C20 auto with 4.10. I swapped trans, new mounts, had driveshaft rebuilt and balanced twice, once troubleshooting the vibration, 2nd time shortening the driveshaft for the 7004r trans. Replace tires, had them balance multiple times, rebuilt dana 60 rear axle, spent 2 years chasing the problem. Finally on a hunch took the driveshaft (2 piece) to a different shop, then said the spline and coupler connecting the 2 shafts had plan replace them and no more vibration. 1st shop did junk work.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
