Old 12-30-2017, 09:38 PM   #401
DURG
DURG's Avatar
Re: DURG's Black 65 C10
It had some cracks. I used two part epoxy.
1962 Impala SS 383 stroker Tremec TKO 600 Black
1965 SWB BBW Fleetside Custom Cab PB Coilover setup Black
2003 100th Anniversary Road King Classic Silver Black
DURG is offline   Reply With Quote
Old 12-30-2017, 09:40 PM   #402
DURG
DURG's Avatar
Originally Posted by gringoloco View Post
I dig the air cleaner, maybe clean up the holes with a dimple die?
They would have to face out as the air cleaner is right against the housing. I don't think that would look good. And I don't have dimple dies LOL.
Old 12-30-2017, 09:42 PM   #403
DURG
DURG's Avatar
Originally Posted by northern 85 View Post
I like it!!! Is there a way you could put a flare on the end of the snorkel?
I tried a little with a ball peen. I need to use it against a dolly. The snorkel metal is pretty thin but it had a flare originally, so I'm sure it can be done.
Old 12-30-2017, 09:46 PM   #404
DURG
DURG's Avatar
I put another hole between the writing and the snorkel today. Also installed the water outlet wand a coolant bypass hose. Started mounting a coolant overflow bottle. Measured up and ordered battery cables. Ordered 2 Auto meter pro lite 2-1/16"gauges which I am going to mount in the vertical rectangular spot on the dash.
Old 12-31-2017, 01:22 AM   #405
gringoloco
A guy with a truck
gringoloco's Avatar
Keep plugging away Glad to see you back on this, it was part of my inspiration to go with PB coilovers on my junk
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
Sporadically present, non-dues paying member of the world-famous Louisiana Classic Truck Club (LCTC).
gringoloco is offline   Reply With Quote
Old 12-31-2017, 09:32 AM   #406
northern 85
northern 85's Avatar
Hopefully i can come see it in person this summer!!!!
northern 85 is offline   Reply With Quote
Old 05-14-2018, 09:05 PM   #407
DURG
DURG's Avatar
Brakes done except bleeding. Added coolant. Scraping old windshield sealnt off channel. Cut holes for gages. Cut the four corner wood pieces for the bedwood.Really need to charge into replacing the entire wiring harness soon.
Old 05-15-2018, 11:05 AM   #408
aggie91
I'm just glad to be here!
aggie91's Avatar
glad to see you are still at it. seems like life can get in the way of making progress on a project...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 05-23-2018, 05:43 PM   #409
made2drag
made2drag's Avatar
Love it!
made2drag is offline   Reply With Quote
Old 06-10-2018, 08:55 PM   #410
DURG
DURG's Avatar
Couple pieces of wood fitted to the wide wheel well.
Old 06-12-2018, 05:16 AM   #411
northern 85
Looks great!!!
Old 06-13-2018, 09:16 AM   #412
timmytimm3
Keep at it man!
http://67-72chevytrucks.com/vboard/s...d.php?t=742865
66 SWB, C4 Dropmember
timmytimm3 on IG
"If you don't have time to do it right the first time, when will you?" -Dad
timmytimm3 is offline   Reply With Quote
Old 06-22-2018, 03:35 PM   #413
DURG
DURG's Avatar
Originally Posted by timmytimm3 View Post
Keep at it man!
Wood cut and routered. Test piece stained and varnished.
Old 06-23-2018, 08:46 PM   #414
DURG
DURG's Avatar
Old 06-23-2018, 08:49 PM   #415
DURG
DURG's Avatar
Wood stained and 2 coats of semi gloss marine varnish. Tranny cooler lines done. I think the wood will look good with the unpolished stainless strips and stainless carriage bolts.
Old 06-25-2018, 12:36 AM   #416
gringoloco
A guy with a truck
gringoloco's Avatar
Agreed. Gonna be a very nice, but subtle look
-Chris
Old 06-25-2018, 04:27 PM   #417
likaroc13
Rollin' Old Skool
Looking good!
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 07-07-2018, 07:28 AM   #418
northern 85
NICE!!!! When can i test drive it??
Old 08-13-2023, 09:53 PM   #419
DURG
DURG's Avatar
5 year update LOL. Fired up the truck finally. 385 fast burn GM crate motor. I had been dreading installing all new wiring and finally started so I could get this thing running. Using American Autowire kit like I did on my 62 Impala.
