Old 08-18-2023, 01:09 AM   #4126
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: What did you do to your truck today.The 3rd chapter
Originally Posted by indymachinist View Post
Worked on my first vent window rebuild
I admire your courage and tenacity.
Pix?
Old 08-18-2023, 04:23 PM   #4127
indymachinist
Pix?
It’s going pretty well so far really. I’ve been just sneaking in a little time here and there where I can. I work in a machine & fabrication shop so I have access to a lot of tools the average shade tree mechanic may not. Even so, getting the rivets re squished nicely is not fun. I have messed up a couple and had to grind them back out and redo.
Brothers Trucks has a really nice youtube video showing the process of putting in new seals.
I will say, if you want them “nice” like rechromed or powder coated or whatever you are far better off just letting someone do them for you. My truck isn’t super nice but not exactly patina either so I’m just giving the chrome a light scotchbrite and calling it good.
Edit: if you are going to do this don’t forget the glass setting tape. It is not included in the precision vent window seal kit and you need it to put the glass back in the frame.
-Curt
My 1968 Chevy shortbed stepside build
indymachinist is offline   Reply With Quote
Old 08-18-2023, 11:36 PM   #4128
'68OrangeSunshine
Fifty-something years ago, glaziers would use a thin sheet of porous rubbe, and wet it with regular motor oil. This dissolved the rubber and it got super tacky, then cured hard with the glass in the frame. I don't think you can get that stuff anymore. I replaced the regulator in my '71 Jimmy in 2006. A friendly glass shop -- they'd just replaced my windshield and trim surround -- let me use some silicone or urethane they had. Industrial stuff. Took 24 hours to harden. We taped the drivers side window and they said not to break the tape for a day. Turned out I was on location in Phoenix, summer of course, and it was at least 114*. I don't have A/C.
The vent windows were fine then. But a PO's sloppy rivet on the drivers side tells me my vent windows were not original.
I kind of rely on winging the vents all the way out for forced air. Us Rednecks call it ''System 2-40.'' Roll down both windows and drive at least 40 MPH.
Early this spring, the tension on the drivers side vent wing went slack. No spring tension al all.* Shaft may have broken, or retaining nut fallen off. Won't know till I pull it.
A couple of years ago [pre-covid] I talked with a guy in the Northwest, who did pairs of vent windows for what I thought then was a lot. His price is double that now.
OER vent window sets are spendy now too.
*For now, Iuse a bunji cord to wing the vent out. Hassle when I have to lock the truck.
Old 08-20-2023, 06:45 PM   #4129
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Not today really but will be soon. I received my new battery cables from Roger Koop and they are top notch as Rogers stuff usually is. It's just time to replace the 51 year old factory battery cables, especially the negative one.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 08-22-2023, 04:36 PM   #4130
don t. - 72gmc
New plug wires.
Filled radiator.
5 gallons of new gas in the relined tank.
Cranked for 30 seconds.
Pumped go fast pedal.
Cranked for another 10 seconds, she fired up and ran.
Had a gas line, carb/filter leak.
Fixed that. Fired right back up again.
1st time I've heard it run in over 7 years.
Im giddier than a skool girl(big grin)...Don.
don t. - 72gmc is offline   Reply With Quote
Old 08-22-2023, 04:40 PM   #4131
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
nicely done, congratulations!
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
Old 08-22-2023, 05:26 PM   #4132
rechinca
rechinca's Avatar
About 10 hours in wet sanding off the hard as nails black spray paint. Nothing would touch it without ruining the original orange under it. Super thin, previous spot paint repairs, scratches, faded to bare in some spots, but going to finish and coat in Sweet Patina. Labor of love or madness, but it’s getting closer! Had the rally wheels blasted and then painted with the Duplicolor Ceramic Engine paint with the van centers. C10 Intervention show in a couple of weeks so have to get it finished this weekend!
1971 Custom/10 - 350/3 speed, Orange/White roof
rechinca is offline   Reply With Quote
Old 08-22-2023, 05:38 PM   #4133
pjmoreland
pjmoreland's Avatar
Looking good! I approve of the color
Took my wheels over to Les Schwab for dynamic balancing. Currently, the wheels only have weights on the inside lip.
pjmoreland is offline   Reply With Quote
Old 08-22-2023, 05:41 PM   #4134
samkost
samkost's Avatar
Much better after your hard work rechinca
Enjoy your C10 Intervention
samkost is offline   Reply With Quote
Old 08-22-2023, 06:16 PM   #4135
rechinca
rechinca's Avatar
Bluetooth wheels! Agreed on the color, for some reason the Light Orange has always been my favorite! I had to have Americas Tire move mine to stick on weights due to the drop spindles. Even with the lip on the lower control arm ground back they still rubbed with the outer-lip mounted ones.
Old 08-22-2023, 06:18 PM   #4136
rechinca
rechinca's Avatar
Thanks man, lots of duct tape on the fingers but still lost a lot of skin🤣! She isn’t perfect, but I am liking the results. Even my wife said she can finally see my vision in removing the black, so I must be succeeding.
Old 08-22-2023, 06:18 PM   #4137
72c20customcamper
72c20customcamper's Avatar
Flushed the old brake fluid it was really contaminated with water . Ordered new shoes and dropped off the drums to be turned. Found an old time garage near me that has the drum disc lathe
This is just from the front used almost a quart before it ran clean
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 08-22-2023, 08:24 PM   #4138
Casper42
Casper42's Avatar
New technology! Stereo with bluetooth from Classic Car Stereos - "Slidebar" radio, dash "stereo" speakers and underseat subs/tweets.
Also attended the "Classic All Chevy" '55-'72 car show on Sunday
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass
New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus!
Casper42 is offline   Reply With Quote
Old 08-22-2023, 09:35 PM   #4139
Jim Boy
I finally did the manual to power steering conversion. I'm in love again only problem she is a 68 model and I could go for something older that has matured. The 68 is named Jim Boy after a boy named Jim on a farm across the road. Now that I'm in love again I'll have to change it's name to a female calling. I think Beulah fits the bill, which is Jim Boy's mother's name. Jim Boy is his real name, quite the family. Have a good one eh! Ron
Jim Boy is offline   Reply With Quote
Old 08-22-2023, 10:55 PM   #4140
Steeveedee
Who Changed This?
Steeveedee's Avatar
Nice looking truck! I wish my truck was blue instead of orange...
~Steven
Simi Valley, CA
Old 08-23-2023, 06:13 PM   #4141
'68OrangeSunshine
I'm a big fan of Orange Trucks.
Old 08-23-2023, 07:29 PM   #4142
72c20customcamper
Decided to replace all the wheel cylinders rubber hoses and shoes . Found one rear wheel cylinder leaking so the others were on their way out . My next project is to get an ibeam and remove the post it’s always in the way
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-23-2023, 10:17 PM   #4143
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
Me too, I think they are the best.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 08-24-2023, 10:44 PM   #4144
'68OrangeSunshine
I was thinking, ''Wait, What happenned to his paint? Didn't he just repaint the whole rig?''
Then I realized this was a C/10 Fleetside, not the C/20 long Stepside.
Good luck on removing the roof support.
Old 08-25-2023, 02:22 AM   #4145
68bowtie
68bowtie's Avatar
I thought the exact same thing for a moment!
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce
Thank you all so far you are angels!!
68bowtie is online now   Reply With Quote
Old 08-25-2023, 08:45 AM   #4146
72c20customcamper
This is the Anniversary truck. The support is for the second floor I had an engineer look at it a few months ago and he drew up some specs for what size Ibeam would be needed I just haven’t gotten around to it .
I got two
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-25-2023, 08:03 PM   #4147
Casper42
Casper42's Avatar
New B&M transmission vacuum modulator (TH350). What a difference from my stock, 51 year old unit. I had been shifting from 1>2 at about 30mph, now it's just under 20mph, under normal driving. I bet I'll see a tick up in MPG! LOL
Now Gettin'r ready for Sunday's ALL C-10 Truck Show in Issaquah, WA
Old 08-28-2023, 04:56 PM   #4148
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Got in my new "custom" SPID from Jeff Lampe at the Out in the Shop today. I f**k up the first one, which I knew I would do one way or the other, so I am glad I was smart enough to have ordered two.
Jeff Lampe does fabulous work - I don't think there is anywhere else you can get a SPID that looks this close to original
Richard
Old 08-28-2023, 05:46 PM   #4149
67C10Step
67C10Step's Avatar
Hopefully fixed the leak in the speedometer gear housing, cleaned up the PCV valve as a precautionary move, and looked for my oil leak up front. Looks like timing chain cover and if I go in that deep I guess a new gear/chain set would be in order along with water pump on this old engine. Might go ahead and get the correct set of pulleys for power steering install.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 08-28-2023, 06:45 PM   #4150
Jiggers72-GMC
Jiggers72-GMC's Avatar
Looks totally original, well done Rich and Jeff
Gerry, North Bay Ontario
1971 Chevy K10 short stepper, 518 med green & white
1972 GMC C1500 long box, dark Brown, owned since 1977
1969 GMC C2500 manual
Jiggers72-GMC is offline   Reply With Quote
