Old 08-18-2023, 03:46 PM   #1
don t. - 72gmc
Sorry...another HEI plug wire thread
I have a stock 400 BB, no ram horn manifold.
I'd read here, plug wires for a 75 vette will fit. Bought a set at Advance. The clips for both ends did not click on as they should. They were real loose. No one there could help further.
Another search here, I bought a set of AC/Delco 9088S wires. The plug end is a 90 vs. a straight boot. They are way too close to the exhaust manifold. So close, I can not get the #4 wire on the plug. They are going back to Amazon.
Another 2 hours of searching...
... maybe AC/Delco 9508D will fit.
... maybe Napa bel700103 will fit. This one has a coil wire which I still have.
I know some will say...buy bulk, make your own. I tried that years ago. In my case, was a waste of $'s. Never could get the connections correct.
Thanks much...Don.
don t. - 72gmc is offline   Reply With Quote
Old 08-18-2023, 04:19 PM   #2
Lee H
Lee H's Avatar
Re: Sorry...another HEI plug wire thread
The 75 vet wires are for a small block with HEI. The end will not fit on a points distributer which you have found out. Some of the wires are so short they probably will not fit a BB. After many frustrating experiences I switched to making my own. I buy bulk MSD wire, boots, and ends, and most importantly a quality set of real spark plug wire crimpers. After 2 or 3 trials they can be made up in about 3 minutes to whatever length is right for you. Good luck, Lee
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 08-18-2023, 05:00 PM   #3
OregonNed
OregonNed's Avatar
I made my own too and it was very satisfying to get the right lengths just how I wanted them..
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 08-18-2023, 07:17 PM   #4
MikeB
MikeB's Avatar
What type exhaust manifolds and what type distributor?
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 08-19-2023, 07:44 AM   #5
don t. - 72gmc
They look like typical 1970 GMC Sierra exhaust manifold.
I have a Skip White HEI dizzy.
Sorry for the lack of info.
HTH...Don.
Old 08-19-2023, 09:08 AM   #6
MikeB
MikeB's Avatar
Does the distributor cap have male or female terminals?
Do your exhaust manifolds look like these?
Mike
Old 08-19-2023, 02:20 PM   #7
don t. - 72gmc
Cap has male terminals.
Exhaust manifold...
Thanks for your time...much appreciated...Don.
Old 08-19-2023, 10:20 PM   #8
70STOVEBOLT
70STOVEBOLT's Avatar
1975 Chevy truck with 454 will work, OEM style have straight boots. I got mine from NAPA, don’t remember the part number. Only put 500 miles on them before I put headers on the truck and went with 135 degree boots. I might still have them. If you are interested let me know and I will look for them.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 08-20-2023, 12:08 AM   #9
northerngmc
northerngmc's Avatar
This is what I used on my 68 396 when I went to an HEI distributor. Stock manifolds and it worked well. They have an HEI end for the distributor and straight caps for the plug end.
I also tried the Corvette wires first and realized that was a small block solution.
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 08-20-2023, 04:22 AM   #10
MikeB
MikeB's Avatar
OK, I'm a dumbass. You said 400 BB, and for whatever reason I was thinking 400 small block. Listen to the two comments above.
Mike
Old 08-20-2023, 10:50 AM   #11
jumpsoffrock
Let's be honest, if people have a 400, they should say 400. If folks have a 402, they should say 402.
I used a set from a 1976 454 for a chevy C20. But maybe they aren't the correct lengths for folks who want a very clean and organized look.
The brand is a popular very high quality Japanese brand--popular with Japanese car folks for many many years--NGK.
NGK 51373
~$30
They're bright blue which might bother some folks, I don't care about color, i just want something I KNOW is high quality. It doesn't hurt that they glue the boots to the wires.
jumpsoffrock is offline   Reply With Quote
Old 08-20-2023, 12:19 PM   #12
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
NGK 51373
~$30
Really? When GM never marketed or badged them as 402s. If it was in a truck they called it a 400 in a car it was a 396.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 08-20-2023, 02:25 PM   #13
jumpsoffrock
Ya, tell me 'bout it. http://67-72chevytrucks.com/vboard/s...d.php?t=834934
But my point isn't about how absurd GM is, but rather about helping folks specify what exactly they're working on so the get the most accurate info.
I don't think I've ever seen quite as much confusion as I've seen on GM forums with people mixing up 400 sbc's and 402 BBC as a result of GM's odd badging and literature.
Old 08-20-2023, 03:43 PM   #14
don t. - 72gmc
Sorry for misidentifying as a 400 BB
SPID clearly shows a 396....
Thanks for the tip on NGK plug wires....Don.
Old 08-20-2023, 06:12 PM   #15
MikeB
MikeB's Avatar
I didn't mean to start a battle here! If I had looked past the "400", I would have seen the BB and would have known it was a 396 or a 402, regardless of what Chevrolet called them.
Mike
Old 08-20-2023, 07:31 PM   #16
jumpsoffrock
Yeah I apologize for coming off confrontational. Sadly just reading (my) words on a screen can leave out context; I don't want to sound like a bully or like I have a genuine problem.
Old 08-22-2023, 04:28 PM   #17
don t. - 72gmc
Deed is done.
I bought Napa part # bel700242. Straight boot on the plug, 90 on the dizzy.
#5 was a bit short but I made it work. All others were goo to go.
Thanks all...Don.
Old 08-22-2023, 04:31 PM   #18
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Thanks much...Don.
Silicone Taylor Pro Series 8mm 76032 spark plug wires, they're made to fit your application. They fit my 71 BBC with a Delco HEI nicely.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
