![]() Join Date: May 2011
72 k5 door
Aftermarket doors.What maker is better fit.Who has experience.I need a driver door.
2WD Jimmy
![]() Join Date: Mar 2005
Re: 72 k5 door
Re: 72 k5 door
You can cut down a truck door that’s what the factory did your in the best place to find one ,original anything is better then repop
Re: 72 k5 door
Most likely cut a door.Just a check see if anyone had better luck out there with repop.I know most all are massaged a bunch.Thanks for replies.
![]() ![]() Join Date: Jul 2003
On my 1970, I cut down original 1970 truck doors, and added the latch reinforcement plates, and the long screw by the vent window. Of course the fit is as good as possible with these vehicles.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. ![]() 1970 K20, To be a clone of my Grandfather's K20, Dark Blue poly, 350, 4 speed, 16.5" X 8.25" Kelsey Hayes wheel option, tilt, tach, vacuum, AM radio. Latest project truck 1972 Cheyenne Super 20 2WD, Dark Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 46k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 67k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
Re: 72 k5 door
![]() Join Date: May 2006
Re: 72 k5 door
I'm having a problem with the rear window channel bracket
Re: 72 k5 door
So what problem with bracket?
Re: 72 k5 door
The rear window channel didn't line up, did some tweaking and bending, and now it sorta fits better
Re: 72 k5 door
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 09-09-2023 at 08:36 AM. |
