Old 08-27-2023, 11:05 PM   #1
desert-rat
Location: 3,018 feet above the SoCal/Mojave Desert region.
Exhaust manifolds glowing red.
First start up after rebuild.
2,000 RPM break-in and noticed they were glowing. So I shut it off. I think the carburetor needs to be tuned because I can't get the RPM past 2,000 when WOT.
Just glad I was doing this in the evening outside my garage. I was able to notice the glow.
desert-rat is offline   Reply With Quote
Old 08-27-2023, 11:47 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Exhaust manifolds glowing red.
Lean mixture. In general, high idle speeds will give a lean mixture unless the choke is closed slightly during break-in. Closing the choke a little will cause the speed to increase. You just need to use something to hold it slightly closed at an optimum idle speed, since the automatic choke will be hot.
~Steven
Simi Valley, CA
Old 08-28-2023, 12:22 AM   #3
RustyPile
RustyPile's Avatar
Timing too retarded will cause the same thing.. Spark fires late and the burn process hasn't completed when the exhaust valves open.
RustyPile is offline   Reply With Quote
Old 08-28-2023, 09:45 AM   #4
1967GMCC20
1967GMCC20's Avatar
Vacuum leak too. Inspect above notes, and correct.
1967GMCC20 is offline   Reply With Quote
Old 08-30-2023, 03:37 AM   #5
desert-rat
So I finished the cam break-in. All went well. The timing was off so now that's been adjusted. Except the rear main seal is dripping oil like crazy. So I drove the truck to the shop that rebuilt the motor. The shop is gonna keep the truck over the weekend to repair the oil leak. Once that's done, gonna flush the water and refill with coolant, slap the new cowl hood on, and enjoy.
Old 08-30-2023, 11:35 PM   #6
53burb
53burb's Avatar
so it was just the timing being off? Was it a significant amount?
53burb is offline   Reply With Quote
Old 08-31-2023, 02:47 AM   #7
Rust_never_sleeps
Rust_never_sleeps's Avatar
Is that just because it leans out the mix, or some other factor?
Rust_never_sleeps is offline   Reply With Quote
Old 08-31-2023, 06:39 AM   #8
desert-rat
Not sure if bad timing had anything to do with the glowing manifolds. Not sure what's a significant amount for the timing, but it was hard to start, idle was rough, the idle was almost like a drag car, very little power. Adjusted the distributor and the carburetor multiple times. Checked timing with a strobe. Got it to idle around 700. Now she purrs like a cat.
Old 08-31-2023, 09:31 PM   #9
53burb
53burb's Avatar
cool...thx for the update
Old 09-01-2023, 11:20 AM   #10
MikeB
MikeB's Avatar
Was just one part of one manifold glowing red? That could mean a problem only with that cylinder. Have to wonder what the spark plug, valve, and top of piston look like.
Let us know when you find the culprit.
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 09-06-2023, 08:25 PM   #11
maverickmk
A carb meters the fuel by "sensing/reading" the incoming flow of air. If there is air be introduced into the intake after the carb it will cause a lean condition because it is getting more air than the carb is calibrating for.
maverickmk is offline   Reply With Quote
Old 09-06-2023, 09:47 PM   #12
Rust_never_sleeps
yep, just wasn't sure if there was some other effect
Old 09-06-2023, 11:49 PM   #13
maverickmk
Gotcha' - Sorry, I didn't mean to be condescending
Old 09-07-2023, 12:40 AM   #14
Rust_never_sleeps
no sweat
Old 09-07-2023, 09:57 AM   #15
MikeB
MikeB's Avatar
Not condescending at all. But a good explanation of a lean condition caused by a vacuum leak.
Mike
