Old 07-10-2023, 03:49 AM   #601
Lokin4AReason
Lokin4AReason's Avatar
Re: Disc Brake Upgrade Reference Thread
Any update(s) to could be used w the 1st post to the thread ?
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
Old 07-14-2023, 08:58 PM   #602
Captainfab
60-66 Nut
Sorry but I don't understand what you are asking.
Old 09-01-2023, 12:46 AM   #603
Lokin4AReason
At what is needed to convert a 6 lug drum to 6 lug disc w stock wheel(s) 15"
As in , what worked with obtaining part(s) from a salvage yard to the part(s) store
Old 09-01-2023, 01:21 AM   #604
Captainfab
60-66 Nut
I do not recommend using the '88-'98 LD 2500 spindles rotors and calipers to convert to a 6 lug disc brake. Several people have had issues with not being able to achieve proper caster. Until someone uses those parts and discovers the secret, it is a much safer bet to just use the squarebody spindles, balljoints, tierods, calipers, etc along with the aftermarket 6 lug rotors. If you choose to make the conversion using the factory parts as described in post#1 of this thread, do so with the understanding that it may not work correctly.
No matter which way you go. You can not use original '60-'66 6 lug wheels with disc brakes.
