Old 09-03-2023, 12:33 PM   #12
georgieb51
georgieb51's Avatar
Re: manual Choke piece missing on my Model B carb
Originally Posted by RichardJ View Post
georgie51, after several posts, you still haven't made it clear what you actually have or what you really need. Showing pictures of someone else's carb or a carb you used to have, doesn't make it any clearer.
If you need the swivel, Mike's has it in their catalog.
If you look at the end of your choke cable, you can possibly see what you had on there before. The choke arm shown by Chevy nutcase, is the style I had on my '67 292.
The end of the cable has to be bent into a "S" shape. If you break that "S" off, it is surprisingly difficult to re-bend to that shape. If you make the bend(s) too tight the wire will snap.
The cable for the swivel choke arm is straight.
I will write more later with better photos. This project started last week and then my daughter was killed in a horrific collision so I am not too good at getting things in order here, I will try again later
1972 Chevy Custom Deluxe Highlander, owned 34 years.
1970 GMC Sierra Grande 2500, unrestored, original.
1970 Chevy K10 Short Wide-bed, working on restoration..
1967 Chevy K10 Short Stepside, unrestored original.
1969 GMC CST (Longhorn) 396, buckets, unrestored.
1995 GMC K2500, 65,000 miles, 454.
georgieb51 is offline   Reply With Quote
