Old 09-03-2023, 04:56 PM   #1
kcstreetracer
Cpp spindle wheel bearing issue
Hey guys I got cpp lowering spindles and cpp disc conversion for the front. I have 2 issues I'm concerned with.
1) The hole for the Cotter pin is nowhere near the castle nut. It's at the front end of the spindle so it wouldn't keep the castle nut from backing out.
2) The castle nuts has to be so tight that the wheel won't spin. If I back it off enough for it to spin the bearing isn't seating in the race properly and there is wobble. Did I get some junk parts or am I missing something here?
I've jacked with this over a hr. Done numerous times before with no issues on other vehicles
1968 C10 SWB, mild 355,5/7 drop, budget frame off, piecing it back together!
kcstreetracer is offline   Reply With Quote
Old 09-03-2023, 05:32 PM   #2
Warrens69GMC
Warrens69GMC's Avatar
Re: Cpp spindle wheel bearing issue
Did you get the model specific one for 67-72 or the 73-91 spindles?
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 09-03-2023, 05:59 PM   #3
kcstreetracer
i believe model specific 67-72
Old 09-03-2023, 06:39 PM   #4
Warrens69GMC
Are your rotors 1" or 1.25" thick?
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 09-03-2023, 06:53 PM   #5
kcstreetracer
1.25"
i was thinking about trying new wheel bearings. Would i just go to oreillys and be able to get the correct ones if i ask for 71-72 c10 and have it match up to the cpp spindles?
