#30 | |
Re: My 89 CC Dually: Double Wide
The latest update.... The lower column bearing cage disintegrated & the replacement XJ shaft was not in a good state. Seems the bushing/seals for the joint bearing cups had failed or were failing. The joint @ the box end of the set-up was 'sticking' on one plane of movement vs easily moving. I went ahead & got another new/aftermarket XJ shaft & a fresh lower bearing & support for the column end. I'm going to watch the shaft a little closer this round & if the same issue w/the seals @ the bearing cups happens, I'll go on e-bay & get a used OE XJ shaft. I drove it around again last night. Hit 5k rpm easily so the fuel supply issue was the collapsed hose. Now I can get it inspected + get the 2nd/PASS side tank & pump swapped. We're going to pull the A/C compressor, drain the oil, & re-charge the system while I'm @ the stealership. After 7yrs, my buddy now seems to think when he charged it initially, he might have had the machine selected to add oil as it was adding freon.... which would have been too much & account for the compressor shutting off above anything above idle speed.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-06-2023 at 12:17 PM. |
| Bookmarks |
