Old 06-27-2017, 09:07 AM   #126
jessemthompson
Re: 5.3 into 72
My old trans was a TH350, but I used the driveshaft out of the donor vehicle. An 07 Suburban.
jessemthompson is offline   Reply With Quote
Old 07-05-2021, 03:16 PM   #127
jessemthompson
Re: 5.3 into 72
I haven’t touched this post in a long time. Today I installed an Eaton posi carrier with the 3:73’s that were already in the rear end. I lucked out and the factory shims put the backlash right where it needed to be. It’s nice to have some traction now and not be a one tire fryer. I think next weekend I may install tear disk if I can figure out the booster/master combination I wanna go with.
Old 08-09-2021, 10:14 PM   #128
EdwardSams
Re: 5.3 into 72
Nice build! Thanks for resurrecting this thread. Good reading.
EdwardSams is offline   Reply With Quote
Old 12-25-2021, 11:05 PM   #129
jessemthompson
Re: 5.3 into 72
So tomorrow I start the cam swap on the 5.3. I’ve been waiting for years to do this. I went with the Truck Norris cam from BTR. My 5.3 is DOD, so the heads are coming off to replace the lifters. I have an autocal from black bear performance with a bae tune loaded for the cam. Hopefully everything goes smoothly.
Old 12-26-2021, 05:57 PM   #130
LS short box
Re: 5.3 into 72
Since you are doing a cam swap are going to upgrade the valve springs and push rods. I would. Depending on your engine mileage I would also replace the plastic lifter guides. They are cheap.
Old 12-27-2021, 08:37 PM   #131
jessemthompson
Re: 5.3 into 72
I upgraded the springs, put in a set of LS7 lifters, new lifter trays and I upgraded the rocker trunnions. My 5.3 HAD the DOD, so the heads had to come off and the lifters had to be replaced. Now there’s just the process of tuning with black bear performance.
Old 01-02-2022, 10:54 PM   #132
jessemthompson
Re: 5.3 into 72
So today I installed a cpp booster/master/prop valve. The factory booster bracket looks awful and I needed a disc/disc mc since it m going to be installing rear disc brakes. Hopefully by the end of the week. The new booster setup looks so much better. I also used captainfabs brake booster bracket. It worked out great.
Old 01-08-2022, 10:31 AM   #133
bigmoe
bigmoe's Avatar
Re: 5.3 into 72
You should make a filler piece for the opening on the front of your engine cover.
Have you had a chance to drive it? How do you like the new cam?
bigmoe is offline   Reply With Quote
Old 01-08-2022, 09:21 PM   #134
jessemthompson
Re: 5.3 into 72
I got it started and did some data logging. Sent the file to my tuner and I’m waiting for an updated file. I wasn’t able to really open it due to the tune not being dialed in. As for the engine cover. I shaved another intake to put on so I could get rid of it. Come to find out I put all that time in for nothing but the experience. I didn’t realize I had picked up a square port intake. I have cathedral ports. Btw your cover does look good with it filled.
Old 02-26-2022, 09:35 AM   #135
jessemthompson
Re: 5.3 into 72
New idle clip with the BTR TRUCK NORRIS cam.
https://youtu.be/OuorqPhfocQ
Old 09-11-2023, 05:43 PM   #136
jessemthompson
Re: 5.3 into 72
Finally got around to building a custom intake and airbox for my swap. Now I feel like my swap looks complete.
Old 09-11-2023, 06:54 PM   #137
bigmoe
bigmoe's Avatar
Re: 5.3 into 72
Looks good. Not many make the effort to properly isolate the intake from the engine bay heat.
Old 09-12-2023, 08:25 AM   #138
clay68c10
clay68c10's Avatar
Re: 5.3 into 72
Nice ride. I'm copying your gas tank idea.
What radiator are you currently using, and do you like it?
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 09-12-2023, 02:10 PM   #139
jessemthompson
Re: 5.3 into 72
I have a factory replacement radiator
Old 09-12-2023, 09:17 PM   #140
LS short box
Re: 5.3 into 72
Just my .02 but a generic LS swap radiator makes the radiator hose routing a bit cleaner since the inlet and outlet are on right side of the radiator. On my 68 I ran a AFCO generic LS radiator. Biggest I could fit. Didn't have a any cold air but it is a good idea.
Old 09-13-2023, 08:01 AM   #141
clay68c10
clay68c10's Avatar
Re: 5.3 into 72
Thanks. I'll be needing one soon, my old copper one is done.
13 Tahoe LTZ
Old 09-13-2023, 08:02 AM   #142
clay68c10
clay68c10's Avatar
Re: 5.3 into 72
That looks great, but I'm running the factory airbox, so no go for me.
13 Tahoe LTZ
Old 09-13-2023, 09:30 PM   #143
jessemthompson
Re: 5.3 into 72
I ran two aluminum LS swap radiators. They both only lasted one year. Electrolysis killed them both. With the cost and only lasting a year I gave up and went with a stock radiator. This one has been in for 3 years and hasn’t had any issues.
Old 09-13-2023, 09:40 PM   #144
MySons68C20
MySons68C20's Avatar
Re: 5.3 into 72
Zinc anode is your friend..I have no issues after 7 years with the aluminum radiator using the anode plug in place of the petcock.
MySons68C20 is online now   Reply With Quote
Old 09-13-2023, 09:59 PM   #145
bigmoe
bigmoe's Avatar
Re: 5.3 into 72
I'm trying a cap with an anode attached.
Old 09-14-2023, 12:31 PM   #146
jessemthompson
Re: 5.3 into 72
After the first one I got a petcock with the anode. I had the same results. After that I was done spending so much on radiators. The stock one cools just as well as aftermarket aluminum ones. I’m not spending that much money over an upper radiator hose. My truck is my daily, so I go with what works.
Old 10-15-2023, 08:56 PM   #147
jessemthompson
Re: 5.3 into 72
I finally got a decent engine cover for my swap. I also swapped my transmission this morning for one that doesn’t grind 3rd gear anymore. I’m looking to start doing some bodywork for my winter projects.
Old 10-16-2023, 11:21 AM   #148
rodstored-72
chevy truck fan
rodstored-72's Avatar
Re: 5.3 into 72
looks nice jessie, I am looking for info on air intake systems for my GEN IV and '86 SWB. I would like to know what specifically you used to make up your air intake system & where you purchased it? ...if willing to share.
thanks!
rodstored-72 is offline   Reply With Quote
Old 10-16-2023, 11:45 AM   #149
jessemthompson
Re: 5.3 into 72
The tubing I used was Airaid AIR-100-400 UBI that I bought on Amazon. The airbox I fabricated using sheet metal and plexi glass for the top. I built a template out of cardboard and went from there.
Old 10-16-2023, 05:02 PM   #150
LS short box
Re: 5.3 into 72
Couple of things.
I purchase the intake hoses from a place called Intakehose.com.
In regards to the LS alum radiator in my 98 Wrangler with a LS6/4L60E combo has 15 years on it with zero issues. I bought it from Novak Adapt out of Logan UT. I believe they were built at the time by Griffin.
IMHO many alum radiators fail is because of the the way they are mounted. I like securing the radiator top and bottom with rubber mounts like they did from the factory. Not "L" brackets welded to the radiator tanks.
