Old 09-11-2023, 09:55 AM   #351
68Gold/white
Re: LockDoc's "Low Budget", "Low Maintenance" Project Thread
Leon, the wheels I've seen like those, were 16.5 inch wheels. I hope yours are 16's as you posted...
68Gold/white is offline   Reply With Quote
Old 09-12-2023, 10:13 AM   #352
LockDoc
The Older Generation
LockDoc's Avatar
You had me worried for a while. It wouldn't be the first time I screwed up that way. I thought I had got rid of all the 16.5 dually wheels I had but you never know about me.....
I wasn't able to check until this morning and thankfully they are 16" wheels. I was pretty sure I had measured them when I first dug them out.
LockDoc
Leon
Old 09-12-2023, 11:15 AM   #353
68Gold/white
Glad to hear.
Most of the one ton stuff I've seen was from the 80's and 90's. All the 16.5 wheels I've seen look like yours...
Al the 16" wheels I've seen were drastically different. The 16's were flat where the hand holes were on the wheel. The 16.5 stuff was all curved like the wheels you have.
Of course I have not seen them all....
Are you going to weld up that clearance light hole on the bed, and officially make it 67 in appearance?
Thanks for all you do!!!
Jeff
Old 09-12-2023, 12:18 PM   #354
LockDoc
LockDoc's Avatar
Glad to hear.
Jeff
I was thinking about the side marker light holes last night while laying in bed. (that's why I have trouble sleeping at night... ..) I am not going to be in a hurry to weld them up. I may want to try something special for them.
I don't really do more than a lot of other guys and gals on here but I appreciate the Kudo's.
Thanks,
LockDoc
Leon
Old 09-12-2023, 03:58 PM   #355
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Leon, are those the double sided tape clips on that bed? Save them and I'll buy them from you.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 09-12-2023, 11:22 PM   #356
LockDoc
LockDoc's Avatar
Yes they are, but I am going to put the trim back on it. Sorry....
LockDoc
Leon
Old 09-13-2023, 09:34 AM   #357
Ol Blue K20
K, no problem. I just didn't want them to be thrown away.
Dale
Old 09-13-2023, 10:57 AM   #358
LockDoc
LockDoc's Avatar
Painted one side of the wheels yesterday. Also got the outside of the bed painted. I want to remove the old wood floor before I paint the inside. I left the fuel fill hole because I am going to re-use the auxiliary gas tank. I am also going to put the upper trim on the truck.
My new tires came yesterday. The wheels I am using have an oval valve stem hole and none of the local tire shops have that type of valve stem. (picture below) I found them on line so I will have to order them.
I had my exhaust scheduled to be installed tomorrow. I was close to the shop yesterday and decided to stop in and check on what it was going to cost me. I have had the exhaust installed on three different vehicles by this shop but it was before the big "C" and a new owner. The last one I had done was $350 or $400. When he got it figured up I about fell over.... $1042 total. I said "that ain't gonna work" "I guess I will have to do it myself". The owner is an old aquaintence of mine and he said "we aren't open on weekends so if you want to do it yourself you can do it here". I said I would accept his offer and hope to do it this weekend or next.
LockDoc
Leon
Old 09-13-2023, 10:58 AM   #359
LockDoc
LockDoc's Avatar
Tires....
Leon
Old 09-13-2023, 03:31 PM   #360
clay68c10
clay68c10's Avatar
LockDoc
OUCH!! I'm hearing that exhaust work isn't cheap like it was. I may do my own also, but at home.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 09-13-2023, 05:36 PM   #361
kev2809
low n' slo
kev2809's Avatar
ya its ridiculous for full piping now a days. i ordered a put together kit and welded it up myself. not perfect but who gives a **** lol. nobody crawls under my truck anyways, plus it sounds tough with the flow fx mufflers i put in
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 09-13-2023, 07:52 PM   #362
LockDoc
LockDoc's Avatar
Yeah, I would do mine at home too if he hadn't offered up his shop. The tube bender will make it a lot easier.
If a guy takes his time he can make it look decent. The shop owners shop rate isn't that out of line @ $86 per hour but the tubing and mufflers are up there. Plus any clamps, hangers, flanges, and other stuff add up fast....
We will see how it goes.
LockDoc
Leon
Old 09-14-2023, 08:53 PM   #363
LockDoc
LockDoc's Avatar
I painted the other side of the wheels today. They came out pretty good.
I also started removing the old wood from the bed. I am just using the sawzall to cut the bolts off. With the pieces of wood missing I can get under the metal strips from up above and cut them off. That makes it wayyyy easier....
I am going to take the bed sills down to the sand blaster tomorrow and let him work his magic on them.
Gave the back of the cab a couple of coats of Satin Black paint today also.
Looks like my new valve stems should arrive tomorrow so maybe I can get my tires mounted. That would be nice.
LockDoc
Leon
Old 09-15-2023, 07:53 AM   #364
kev2809
low n' slo
kev2809's Avatar
man its moving quick now, i know this might be a dumb question, are you dropping the rear end some to level it out?
-_--_--_ _________
Old 09-16-2023, 12:15 AM   #365
LockDoc
LockDoc's Avatar
First off I removed the coil shocks as seen in post #340 yesterday, and ordered a set of stock shocks for it. They raised the frame up quite a bit. I won't do anything else until I get the finished bed back on it and see where it sits. That should drop it quite a bit. It should sit the same as it did in post #48.....
I won't be able to get the exhaust done until next weekend now, so that is another week delay. A couple of things I have learned in my many years of car and truck building is expect delays and don't sweat the small stuff....
LockDoc
Leon
Old 09-18-2023, 08:58 PM   #366
LockDoc
LockDoc's Avatar
Well the valve stems did not make it today so we will see what tomorrow brings on that.
I finally had a chance to take the bed sills to the sandblaster this morning. I am going to have a couple of small rust spots to fix when I get them back but it shouldn't take long to do.
New shock absorbers arrived this morning so I went ahead and installed them.
I also painted the drivers side door and fender. The way these trucks are built lends itself well to be painted in sections instead of all at once. All I have left to paint is around the windshield and the hood. It was starting to get a little dark by the time I took the picture so the light wasn't too good.... .It is supposed to start raining early in the morning so I may have to find some inside work to do for a while tomorrow. I am hoping I can work on the inside of the bed and get it ready to paint in the next couple of days.
LockDoc
Leon
Old 09-19-2023, 08:25 AM   #367
68Gold/white
Leon, Are you making your own wood floor???
Old 09-19-2023, 11:38 AM   #368
LockDoc
LockDoc's Avatar
I am on the fence about that right now. I have a new oak wood kit if I want to use it but I really hate to use it on a work truck. I'm thinking about having a friend of mine cut up some used power poles and make the bed wood from that. Here are a couple of pictures of when I used power pole wood in the bed of the '70 Longhorn 4x4 project. I really like it and it is cheap and durable. This one just has a few coats of Danish Oil Finish on it.....
LockDoc
Leon
Old 09-19-2023, 02:56 PM   #369
kev2809
low n' slo
kev2809's Avatar
those look great. does he have a milling machine?
-_--_--_ _________
Old 09-19-2023, 05:33 PM   #370
LockDoc
LockDoc's Avatar
No, all he has is one of those big horizontal band saws for cutting the board thickness. I finished them up with my thickness planer, table saw, and router table.....
LockDoc
Leon
Old 09-19-2023, 05:47 PM   #371
kev2809
low n' slo
kev2809's Avatar
damn those look very nice. I'd roll with that, looks better than the kits and I'm sure they hold up better
-_--_--_ _________
Old 09-19-2023, 06:19 PM   #372
LockDoc
LockDoc's Avatar
Thanks, I will call him tonight and see how busy he is.
LockDoc
Leon
Old 09-19-2023, 06:39 PM   #373
LockDoc
LockDoc's Avatar
The valve stems finally showed up this morning. A friend of mine has a tire machine so I called him to see if he could mount the tires on the Dually wheels. He said his machine wasnt big enough to do those, so I called around to a couple of other tire shops. They either wouldn't do them because I didn't buy the tires from them or it was going to be longer than I wanted to wait. What do you do in that case? Mount them yourself....
After installing the new valve stems in the wheels, I started on the first one. That first one was a bear because of the learning curve. Even though I came in the house and watched a few videos on YouTube it was still a little daunting. The second one was a lot easier because I didn't use any soap on it. That first one was so slippery you couldn't get the tire started on the rim. Two done and two to go. It started raining on me so I had to quit for the day. I will mount the other two in the morning. One of the problems is that I am a lightweight so I don't have enough lead in my arse to hold everything down. It kept wanting to move on me. One thing I'm not short on is determination... I will prevail!!!
EDIT: Added picture of the valve stem box for part number.
New valve stems.
Tire 1 and tire 2.
LockDoc
Leon
Old 09-19-2023, 08:26 PM   #374
junksaver
I love your determination. That is no easy task mounting tires without a tire machine.
68 4wd Stepside
69 2wd Stepside Project
71 2wd Blazer Project
72 2wd 3/4 Ton Project or Parts?
73 4wd Blazer
junksaver is offline   Reply With Quote
Old 09-19-2023, 09:08 PM   #375
LockDoc
LockDoc's Avatar
Thanks much!
LockDoc
Leon
