Old 09-14-2023, 07:32 AM   #1
chrismoore701
chrismoore701's Avatar
Lost my Blower motor speeds
I lost the first two (2) speeds on the blower motor on my 79. Stock setup. Where do I look?
Chris
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 09-14-2023, 08:44 AM   #2
kglowacky
Re: Lost my Blower motor speeds
on the engine side of the firewall between the dryer and the firewall there is a electric plug that has 4 or 5 wires on it, this is how the power gets to your fan motor. It is some sort of resistor as I remember. The yellow wire is the lowest motor speed . Check power to each of these. You should get power to one of these at every speed on your switch. if you don't then switch may be bad if you do then resistor is bad. Doing this from total memory as I am not home to confirm. this info based on my 78 with air. Someone jump in if my info is not correct.
kglowacky is offline   Reply With Quote
Old 09-14-2023, 10:17 AM   #3
Bandit130
Bandit130's Avatar
That is correct. It is the resistor and yes the yellow wire is low speed. If you have a 4 speed fan, you can remove the yellow wire from the connector and have a OFF and 3 speeds. This is what I did cause on mine the low speed always blows when key is on. It was really irritating in winter when first start in the morning air blew from vents before truck warms up.
I believe you can still buy a resistor if you need one.
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is offline   Reply With Quote
Old 09-14-2023, 08:43 PM   #4
v30crewcab
v30crewcab's Avatar
I would check the resistor first, as its easy to get to. you can back probe the plug and see if power is getting thru. the fan switch does go bad sometimes as well but its alot more work to get to.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 09-14-2023, 09:38 PM   #5
kglowacky
agree check resistor 1st
Old 09-15-2023, 03:25 AM   #6
Pontiac1976
Pontiac1976's Avatar
The resistor 1st (burned) out or plug dirty corroded connectors need cleaning. And you may want to check the Gound clean protect. make sure it got 100% good ground.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 09-15-2023, 07:28 AM   #7
chrismoore701
I think I have two (2) plugs on my AC box, but do not see a resistor. Ill look tonight, any pics of where this would be?
Chris
Old 09-15-2023, 08:25 AM   #8
kglowacky
you cant see the resistor only the plug without removal. 2 Screws after you unplug it. Looks like a toaster element once you get it out,
Old 09-15-2023, 08:46 AM   #9
Getter-Done
Getter-Done's Avatar
Here's a video for location purposes.
The early bird gets the worm,
84 Chevy K-20
Old 09-18-2023, 07:18 AM   #10
chrismoore701
thanks, will look into that
Chris
