Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 09-21-2023, 11:14 AM   #1
1774btcrew
1774btcrew's Avatar
I have a few headlight warning buzzers for sale
I was sick of forgetting and leaving my headlights on my 1985 dually so I went to the wrecking yard to pick up an OEM a warning buzzer for it. In the process I grabbed a few extra. This is one of the easiest and cheapest mods to improve your truck. These are plug and play on a lot of squarebodies. It was on my 85. Price is $40 shipped in the US in the continental US for each one
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 09-21-2023, 05:01 PM   #2
SunSoaked
SunSoaked's Avatar
Re: I have a few headlight warning buzzers for sale
I like the idea of an OEM buzzer. I didn't know they just plugged in. Where in the fuse box do they go? Looks like two rows of pins. I'm gonna go look at my 85 and see if it's obvious. I need one.
SunSoaked is offline   Reply With Quote
Old 09-21-2023, 05:02 PM   #3
SunSoaked
SunSoaked's Avatar
I like the idea of an OEM buzzer. I didn't know they just plugged in. Where in the fuse box do they go? Looks like two rows of pins. I'm gonna go look at my 85 and see if it's obvious. I need one. Curious why it takes 7 terminals for a buzzer?
Old 09-21-2023, 08:31 PM   #4
ray_mcavoy
I believe these plug into the "convenience center" as opposed to the fuse box. The convenience center is a secondary electrical panel that GM added to these trucks sometime around 1985 and if I remember correctly it's located somewhere above the gas pedal (the horn relay and hazard flasher also plug into the convenience center).
According to the wiring diagrams, the 7 pins are connected to:
- switched power (ignition)
- "fasten seatbelt" light on dash
- ground
- driver side seatbelt retractor switch
- key present in ignition switch
- constant power
- dash illumination circuit
So in addition to being a headlight warning buzzer, it looks like they also serve as a seatbelt and key-in-ignition buzzer.
ray_mcavoy is offline   Reply With Quote
Old 09-21-2023, 09:30 PM   #5
SunSoaked
SunSoaked's Avatar
- ground
- constant power
Thanks. I'll search for it tomorrow.
Old 09-21-2023, 11:05 PM   #6
1774btcrew
1774btcrew's Avatar
- ground
- constant power
I was hoping you would chime in on this
Old 09-21-2023, 11:06 PM   #7
1774btcrew
1774btcrew's Avatar
I've only used mine the last couple nights but I really like having it
Old 09-22-2023, 12:39 PM   #8
aotte1
I will take two, please. For 84 and 86.
Les
aotte1 is offline   Reply With Quote
Old 09-22-2023, 12:50 PM   #9
1774btcrew
1774btcrew's Avatar
Les
Absolutely ! Do you still have my contact information
Old 09-24-2023, 02:16 PM   #10
SunSoaked
SunSoaked's Avatar
I found my plug. It has 7 pins and is actually marked "buzzer". I will take one. Is PayPal ok? You can message me the details. Thanks
Old 09-24-2023, 06:43 PM   #11
1774btcrew
1774btcrew's Avatar
I can take PayPal. I will DM you with the address
Old 09-28-2023, 12:15 PM   #12
jakewalter
jakewalter's Avatar
I will take one.
Please PM me your payment info.
Thanks so much,
Jake
1967 Chevy SBSS Bone stock
1974 Chevy Cheyenne 4wd long bed
1985 Chevy Scottsdale 4wd long bed
2000 Chevy 1 ton 4wd dually quad cab
2004 GMC Sierra 4wd Super cab long bed
jakewalter is offline   Reply With Quote
Old 09-28-2023, 12:27 PM   #13
1774btcrew
1774btcrew's Avatar
Originally Posted by jakewalter View Post
I will take one.
Thanks so much,
Jake
I will send the p.m. right now
Old 09-29-2023, 08:21 AM   #14
Hart_Rod
Hart_Rod's Avatar
what sounds do they make?
Hart_Rod is offline   Reply With Quote
Old 09-29-2023, 08:31 AM   #15
TKCR
TKCR's Avatar
Just one, if you leave your headlights on. I had gotten one of these from another member awhile back, and it saved me a couple of time. You get so used to your automatic headlights on your modern vehicle, that you’ll forget a lot of time to manually turn off the light in our old trucks. At least I did, lol.
Old 09-30-2023, 05:49 PM   #16
SunSoaked
SunSoaked's Avatar
1774btcrew,
Received the buzzer today. Plugged it in and it works like magic!
Thank you for sharing and sending this to me.
Old 09-30-2023, 06:02 PM   #17
1774btcrew
1774btcrew's Avatar
1774btcrew,
Glad it showed up. I'm really happy with mine as well
Old 09-30-2023, 06:03 PM   #18
1774btcrew
1774btcrew's Avatar
I will take one.
Thanks so much,
Jake
Your headlight buzzer module shipped out yesterday.
Old 10-06-2023, 06:25 AM   #19
calvin78612
calvin78612's Avatar
I'll take one if you'll take a USPS money order. PM me your info.
84 step side
87 swb
calvin78612 is offline   Reply With Quote
Old 10-06-2023, 08:54 AM   #20
jakewalter
jakewalter's Avatar
Works like a charm.
Thanks so much,
Jake
Old 10-06-2023, 11:22 AM   #21
1774btcrew
1774btcrew's Avatar
Postal money order is fine. I Will send you a PM with the details
Old 10-12-2023, 05:50 PM   #22
1774btcrew
1774btcrew's Avatar
ttt
Old 10-23-2023, 10:20 PM   #23
1774btcrew
1774btcrew's Avatar
Ttt
Old 10-28-2023, 09:12 PM   #24
aotte1
Received the two warning burrrers two day. They are exactly as you described.
Great addition to truck.
Thanks,
Les
Old 11-12-2023, 11:19 AM   #25
rwjtexas
Good Morning, Any Buzzers left ? Shipping will be going to zip 77701 ..
Thanks,
Rob
rwjtexas is offline   Reply With Quote
