#1 | |
Re: Squeaking Hydraulic Clutch?
It does not squeak at all when the pedal is not being moved, only when you are actively pressing it in. With the clutch all the way in, all the way out, or with the clutch pedal held stationary in a partially-engaged state there is no noise. It really sounds like it is coming from the pivot stud, but I could be wrong... I would have expected a throwout bearing to make noise when under load (ie when holding the clutch released), but this one does not do that. Its just squeaky when the pedal is moving. Also the noise does not change with the engine on or off. Is it possible for a throwout bearing to somehow make noise when the engine is off and the vehicle is stationary?
1988 "Crane Truck" C30 - 350, SM465, with a 15' knuckle crane - thread 1986 M1009 - 6.2 Diesel, SM465, 2 speed aux trans, NP205 - thread 1979 Corvette - 350 T5 1977 Jimmy - 350, TH400, NP203 1982 Blazer - 350, 700R4, NP208 - Totalled, now a parts truck ![]() Scratch built 16' flatbed trailer - thread |
#2 | |
![]() Join Date: Dec 1999
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
If it squeaks with the truck off it may just be the rubber pad or the pedal bushings.
Pull the rubber pad off the pedal and see if it eliminates the squeak. If it does rock auto has new ones for cheap. 60% of the time it works every time.
1991 Metro commuter 1991 s10 future project truck 1987 V10 backup daily/junk truck 1985 K20 Winter beater 1991 R30(squarebody) c/c flatbed towrig 1994 s10 80"wb custom build |
