Old 09-03-2023, 09:00 PM   #26
Classic Bowties
Always on the hunt...
Re: F/S GM NOS & New Repro Steering Column Replacement Parts
Originally Posted by EdwardSams View Post
Good evening.
I’ll please take one of each of the following. Thx!
#5 / Repro horn contact t/s cancel cam for non-tilt. $13. ***Qty. 1 Sold/Shipped*** Have 2 more on hand/available...
#6 / Repro horn contact pin, spring & retainer kit. $7. ***Qty. 1 Sold/Shipped*** Have 2 more on hand/available...
Ed, confirming that your sent Venmo funds have been received for one #5, one #6 and upgraded priority shipment, USPS is closed tomorrow due to the Holiday so we will confirm shipment of your outgoing order on Tue. 09/05. Thanks again, Mel
***For any return/past customers & friends***
Before sending of any funds, please wait for a confirmed total and instructions for
sending as our payment account info has been changed as of Jan. 2023. Thanks...
Classic Bowties is online now   Reply With Quote
Old 09-04-2023, 10:45 AM   #27
gdelaney5
Mel,
I am interested in a set of any NOS internal components that you still have for non tilt automatic steering column. Could you provide a list and $ for what you still have available?
Thanks! Greg
gdelaney5 is offline   Reply With Quote
Old 09-05-2023, 10:09 PM   #28
Classic Bowties
Good evening.
#5/Repro horn contact t/s cancel cam for non-tilt. $13.
#6/Repro horn contact pin, spring & retainer kit. $7.
Hi Ed, your new repro t/s cancel cam & horn contact kit have been shipped off, the package went out via USPS Priority on Tue. 09/05 and your expected delivery day is this Thu. 09/07. Thanks again for your order and repeat business, let me know if we can help with any other 67-72 parts needs. Mel
Old 09-05-2023, 10:22 PM   #29
EdwardSams
Many thanks!
EdwardSams is online now   Reply With Quote
Old 09-05-2023, 11:24 PM   #30
Classic Bowties
Originally Posted by gdelaney5 View Post
Mel,
Thanks! Greg
Hi Greg, to save a bit of time on our end let us know which wear parts you are chasing and I will reply back with availability and cost. Going off of memory for your column shift non-tilt steering column, we have the NOS upper & lower bearings, NOS lower bearing spacer mount, NOS lower bearing tension spring, NOS upper plastic and rubber bushings, NOS horn contact t/s cancel cam and the NOS turn signal switch and harness. Also pending confirmation of the actual year of steering column that you are working on, we may have the NOS shift indicator pointer, NOS shift indicator lens housing and both NOS chrome shift and turn levers. Let us know, Mel
Old 09-06-2023, 09:43 AM   #31
gdelaney5
Mel,
My column is for a 1972 k10
I will take:
NOS chrome shift levers
NOS chrome turn lever
Thanks,
Greg
Old 09-07-2023, 02:42 PM   #32
EdwardSams
Mel, you did it again. The parts arrived quickly and beautifully packaged. Amazon could learn a thing or two from you.
Thank you.
Old 09-08-2023, 07:22 AM   #33
gdelaney5
Mel,
In addition to my list above, if you have a 4sp overdrive lens for the 72 column I will take one of those as well.
Thank you,
Greg
Old 09-08-2023, 12:00 PM   #34
pjmoreland
pjmoreland's Avatar
****EDITED**** I'm after part number 3916047/474102
I'll take one of these, please, if available.
#4 / NORS horn contact pin, spring & retainer kit. $20. ***Qty. 3 Sold/Shipped*** Have more on hand/available...
Also, please let me know if you have a 3900514 upper spring for a tilt column. Thank you.
pjmoreland is offline   Reply With Quote
Old 09-08-2023, 01:28 PM   #35
Classic Bowties
Okay, we got'ya down for one three pc. #4/NORS horn contact pin, spring & retainer kit, I still need to get to gdelaney5's above column parts request and will check on the tilt only upper cam spring for you next. I can confirm that we do have the 3900514 springs on hand in both GM NOS and OE used, but we always seem to be chasing these often missing/hard to find cancel cam springs for our own tilt column builds. While checking on our available on hand tilt cam spring quantity, would you need/want the upper tilt column specific horn contact t/s cancel cam in either GM NOS, OE used or new repro? We have all three tilt cancel cam options on hand/available ready to ship and these small column parts can all be combined and sent out for the one $7. shipping charge. Let me know, Mel
Old 09-08-2023, 01:36 PM   #36
pjmoreland
pjmoreland's Avatar
I've already got the tilt horn contact t/s cancel cam, but it's missing the horn contact pin/spring/retainer.
Sounds great. I prefer OE on the 3900514 cam spring, if you've got it, but NOS will work, too. Thank you.
Old 09-11-2023, 04:21 PM   #37
pjmoreland
pjmoreland's Avatar
In addition to this...
and this...
OE (preferred) or NOS tilt column 3900514 cam spring
I'm also looking for this:
Clutch pedal push rod for a 2WD SBC
Any chance you might have one?
Old 09-11-2023, 11:27 PM   #38
Classic Bowties
Yes, we do have some of the OE V-8 bell crank/z bar to pedal rods pulled/stored on the shelf, will check on availability/condition and grab you some pics when I get your other items pulled out. Mel
Old 09-11-2023, 11:37 PM   #39
pjmoreland
pjmoreland's Avatar
Thank you
Old 09-12-2023, 03:58 AM   #40
pjmoreland
pjmoreland's Avatar
I'm sorry I keep coming back with more stuff, but would you happen to have a bellcrank frame bracket for a 2WD SBC like the one below?
Old 09-16-2023, 09:50 AM   #41
bowtie72
bowtie72's Avatar
I’ll take the bulb cover and filter for the tilt column.
1968 SWB "Little White Truck"
1972 LWB LS 4l80 "Plain Jane!!"
bowtie72 is offline   Reply With Quote
Old 09-16-2023, 11:59 PM   #42
Classic Bowties
Funds received and the OE used tilt column shift indicator dial lamp steel cap & plastic filter setup have been shipped off, your package went out via USPS ground advantage on Sat. 09/16 and the expected delivery day is Tue. 09/19. Thanks again for your order and let me know if we can help with any other 67-72 parts needs and/or column questions. Mel
Old 09-17-2023, 01:07 AM   #43
pjmoreland
pjmoreland's Avatar
I was able to source the clutch linkage parts locally. I'm still interested in the following two parts:
and this...
Old 09-17-2023, 12:54 PM   #44
gdelaney5
Mel,
Any update on the column parts request?
Thanks,
Greg
Old 09-25-2023, 06:10 PM   #45
pjmoreland
pjmoreland's Avatar
If it's alright with you, I'd like to pass on the following parts:
and this...
I was able to find these parts elsewhere.
Old 09-26-2023, 08:43 AM   #46
omodified
omodified's Avatar
Mel,
Do you have any of the green filters for the tilt shift indicator light? I already have the housing. I’m looking for two good ones.
Board Member #87725
Old 02-26-2024, 04:20 AM   #47
Pep01
Junior Member
Looking for optic holder socket that fits 69 GMC 1500.
Pep01 is offline   Reply With Quote
Old 02-28-2024, 04:21 PM   #48
Pep01
Junior Member
Hello, I’m requesting the thread for the optic cable socket holders
Old 09-15-2024, 09:17 PM   #49
Classic Bowties
^ ^ ^ We pulled these GM NOS and OE Used non-tilt column shift indicator fiber optic cable bulb sockets out for above member Pep01 a while back but never added pics/pricing on the extras. These bulb sockets are ready to ship out, the pricing and payment options are listed in the top post of this f/s thread. Mel
Old 09-15-2024, 10:36 PM   #50
Pep01
Junior Member
Sorry Mel, another member sent me what I was needing. But if you get your hands on some upper and lower 4 row radiator brackets and cushion, I’m needing some. For a 69.
