Old 09-27-2023, 08:06 PM   #12
mongocanfly
mongocanfly's Avatar
Re: Fuel pump relay
ok ..i believe i was getting your pics mixed up as to which is which..the computer im on now has them in order with what you said..my little pad had them swapped..haha
after looking at it more, the pic (your buddys truck) with the white jumper wire looks to be getting the fire signal from the fuel pump relay to fire the other relay....
not really ideal as the ecm fires the pump for a few seconds then stops waiting for a run signal...( i think thats right)..
on the one you say is your sons, that looks more right..
make sure your constant 12v power wire is hot to terminal 30
make sure your getting 12v key on and crank at terminal 86
make sure you have ground on terminal 85
if these are correct when the key is on you should have 12v at terminal 87..for a few seconds
when you cycle the key it should power the fuel pump for a few seconds, then it stops..and waits on the crank signal before firing the pump again
make sure your relay is good..
and you could momentarily put a 12v jumper wire from a known 12v source to the wire going to the fuel pump..it should run if its good
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
