70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Question about American AutoWire Headlight Relay Kit
I bought the American Autowire Headlight relay upgrade kit ( # 500403 ) and wonder if anyone else has installed one of these where did u mount the relays.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
![]() Join Date: Jan 2001
Re: Question about American AutoWire Headlight Relay Kit
I built my own but I mounted the relays next to the battery.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
Mounted the one from LMC, relays next to battery.
Thats what I was thinking, by the battery.
![]() Join Date: Aug 2012
I did the same. Here is a pic of where I mounted my relays
![]() ![]() Join Date: Jul 2002
I used different kit, but mounted the relays and fues near battery
![]() Join Date: Feb 2022
If you are still using the factory battery meter connecting the power source of the headlight to the battery or fuse link block will trick the meter into a charging display. The source of power for the lights needs to be on the other end of the shunt wire. Look at your meter with headlights on and alternator not turning. You should display a discharge. If you have connected to the battery side of the shunt, you will show a charging state rendering the meter worthless when headlights are on.
