Old 08-18-2023, 12:57 AM   #1
Classic Bowties
Always on the hunt...
OE Used Tool Stowage/Repro Cargo Lamp Hdwr Parts For Member Gyrine
Rob, per your sent parts request, we had everything from your want list except for the single NOS deluxe amber side marker. We did have a tool & stowage box setup w/rear support brackets pulled/stored on the shelf that was originally removed from a wood floor donor truck, so the rear brackets had the correct OE bolt, spacer, washer and nut setup for your build. We did find a couple of the OE used #10 x 5/8" screws with the captured washer head, we also have these available new in the OE type black phosphate finish. Let me know on the screws, everything else is totaled up along with the NOS rubber bumper setups from the other f/s thread, will combine ship everything pictured (plus the NOS rubber bumper sets) for $11. via USPS. Mel
Qty. 1 / New repro 8 pc. cargo lamp housing mounting screw, spacer and rubber nut setup w/OE style chrome plated lens shoulder screws.
Qty. 1 / OE used cab pillar seat belt bolt hole plug.
Qty. 6 / OE used rubber retainers for installing firewall pad.
Qty. 4 / OE used rear of tool box support bracket to bed floor hardware.
Qty. 1 / OE used tool box outer flange mounting screw. (or new screws & qty. ?)
Qty. 1 / GM NOS deluxe red side marker lamp.
***For any return/past customers & friends***
Before sending of any funds, please wait for a confirmed total and instructions for
sending as our payment account info has been changed as of Jan. 2023. Thanks...
Last edited by Classic Bowties; 09-11-2023 at 01:03 PM. Reason: Added more hardware
Classic Bowties is offline   Reply With Quote
Old 08-18-2023, 01:02 AM   #2
Classic Bowties
Re: OE Used Tool Stowage/Repro Cargo Lamp Hdwr Parts For Member Gyrine
More pics...
Old 08-18-2023, 01:05 AM   #3
Classic Bowties
Last of the pics...
Old 08-18-2023, 02:45 PM   #4
Gyrine
Mel,
I appreciate you finding these items. On the screws for the tool box insert, I would like the used one and the set of new ones.
Also, do you have the two Philips head machined bolts that attach the BBC heat shield to the floor? I have a shield but no attaching bolts. If you do, please add that to the other items.
Thanks as always.
Rob
Gyrine is offline   Reply With Quote
Old 08-18-2023, 06:22 PM   #5
Mitchell pendley
I would be interested in a orginal set of screws , washers and nuts that holds the tool box flange to the floor of the bed . Thanks let me know if you have any and a price.
Mitchell pendley is offline   Reply With Quote
Old 08-22-2023, 09:39 PM   #6
Classic Bowties
Originally Posted by Gyrine View Post
Mel,
Thanks as always.
Rob
Hey Rob, here is the OE used pass side BBC heat shield hardware that will be added to your shipment, will forward your parts total now. Thanks, Mel
Old 08-22-2023, 10:03 PM   #7
Classic Bowties
Sorry, we are not going to do anymore "Robbing" of the OE used hardware off of these stored tool box setups, the small hardware/detail pieces can sometimes be harder to find than the hard to find parts themselves. We can however supply you with the RPO VK2 tool & stowage box rear support bracket to bed floor mounting bolt/spacer-washer/hardware setup in new repro for either wood or steel bed floor, the 16 piece wood floor set is $12. + ship and the 12 piece steel floor set is $6. + ship. Let us know, Mel
Old 08-22-2023, 10:05 PM   #8
Classic Bowties
Last two pics...
Old 08-23-2023, 11:53 PM   #9
Classic Bowties
Hey Rob, this group of parts have all been shipped off, your combined order went out via USPS Priority on Wed. 08/23 and the expected delivery day is this Fri. 08/25. Thanks again for your order and repeat business, let me know if we can help with any other 67-72 parts needs. Mel
Old 08-25-2023, 05:19 PM   #10
Gyrine
Mel,
Received the parts today. As always, they look great.
The cargo light kit is really nice. I would recommend that to anyone installing a new cargo light housing.
Thanks again,
Rob
Old 08-26-2023, 12:38 AM   #11
Classic Bowties
Mel,
Thanks again,
Rob
Hey Rob, thanks for confirming the safe arrival of your combined order and that you are happy with your purchases. That new repro 8 piece cargo lamp housing and lens hardware set contains all hand picked U.S. sourced pieces that were matched up/compared with the hardware kit from a GM NOS cargo lamp setup, some of these smaller simple details can really make a truck build stand out. Thanks again for your order and continued support, let me know if we can help out with any other 67-72 parts needs for your current build. Mel
Old 10-09-2023, 02:30 PM   #12
Classic Bowties
^ ^ ^ While we have this stuff pulled out, does anyone else need a repro 8 piece cargo lamp housing and lens mounting hardware setup at $14. + ship (pics in above post #2) or a new RPO VK2 tool & stowage box rear support bracket to bed floor 16 or 12 piece hardware setup? The pics and pricing are in above post #7 and we can ship any of these hardware setups for $7. in the CONUS and/or combine with any of our other listed small package hardware setups. Thanks, Mel
