01-13-2022, 09:42 PM | #1 |
Dash pad install issues
Am I missing something? I am trying to install my new dash pad (bought from Brother’s over a year ago) and I can get the bolts along the top sorta in the holes. But then nothing along the front lines up. It’s like I can’t pull it down far enough for those little screws to get close to their holes.
I kinda ovaled out the holes along the top so I can pull it forward/down a little. Do I need to do it more? I guess I don’t wanna go too far with my dremel if I’m totally missing something obvious. Also, those bolts are in stupidest places. |
01-13-2022, 10:43 PM | #2 |
Re: Dash pad install issues
22 or 23 years ago I bought a blue Dash Pad from Brothers for my '71 GMC Jimmy. I removed the Dash Panel, heater control, radio and glove box to get to it.
My new in the box pad was pretty, but I did not notice the stud all the way left wasn't even threaded, until I got to it last. It looked kind of melted. I had to reassenble the old dash and live with it until they sent a replacement free. Getting them to cover shipping both ways was like pulling teeth. Check your piece for factory defects. Even with a good unit, they are a total PIA. Start on the outside ends and work towards the middle. Just get the nut started, then move on. When they are all on, then you can tighten up. Might help if everything is warm, shop, cab, dash pad. They might be stiff if cold.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 01-13-2022 at 10:48 PM. |
01-13-2022, 10:52 PM | #3 |
I had to use a Dremel to slot some of the holes in my dash. Kinda irritated me that I had to modify the truck to fit an improperly made part. It ended up working out and the new dash looks good.
Insert clever text here: |
01-14-2022, 09:56 AM | #4 |
I bought a polyurethane dash pad from GMC Pauls a couple years ago and had to dremel some holes out to get them to go through the dash. Not a big deal, but it does suck to have to slot holes in a freshly painted dash. IIRC, a few of the holes needed slotted to one side or another by about an 1/8" or so depending on the hole....not enough that a new hole could be drilled instead.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
01-14-2022, 11:04 AM | #5 |
The ones I have bought come from Dashes Direct
have fit perfectly
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
01-14-2022, 11:36 AM | #6 |
I have had to slot the top dash holes for both the Dashes Direct and Counterpart pads........
1967 C10 SWB Owner - Rustbelt Restorations |
01-14-2022, 11:32 PM | #7 |
I had the same issue with mine. After researching the issue I just slotted the holes and moved on.
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" |
10-14-2023, 01:04 PM | #8 |
I'd like to add my experience:
The "Counterpart" pad would not fit as described above. The "Just Dashes" fell into place. Perfect fit. |
