Old 08-17-2004, 03:56 PM   #1
Jeremy_5
Truck addict
Jeremy_5's Avatar
body mounts
I have been looking around for a complete set of cab/rad/bed mounts. Is there much difference between Polyurethane, and just normal rubber. I want original oem style, and the sets I have looked at seem to vary in their design. Does anyone know what the correct style should be? And has anyone had any luck with certain sets. Thanks
1956 Chevy Napco
1972 Cheyenne Super
1970 K20
Jeremy_5 is offline   Reply With Quote
Old 08-17-2004, 05:19 PM   #2
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
I've replace body mounts on 2 trucks and went with the original rubber type. Most of the venders here have them. The Poly ones I'm told can make noise.
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 08-17-2004, 05:22 PM   #3
70c10
67-72 Addict!
70c10's Avatar
I have also heard this plus they give a stiffer ride. I would go with stock rubber type. They should hold up for another 30 years!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 08-17-2004, 05:37 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You want good ones?
Go to your local GM dealer:
Core support bushings upper 3951798
Core support bushings lower 3953135
Cab mount rear complete 3957829
Cab mount Front upper 6262169
Cab mount Front lower 6262168
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 08-17-2004, 07:39 PM   #5
69sixpackbee
Are those GM #'s for the 1/2 ton or 3/4 ton pieces?
69sixpackbee is offline   Reply With Quote
Old 08-17-2004, 10:40 PM   #6
Tx Firefighter
sorry, they're half ton numbers. Disregard my post. You may now return to your regular internet viewing.
Old 08-17-2004, 11:16 PM   #7
zooza
Originally Posted by Tx Firefighter
You want good ones?
good to know for the 1/2 ton crowd though! thanks
zooza is offline   Reply With Quote
Old 08-18-2004, 07:42 AM   #8
Joe67
67 is sold
Thanks for the PNs TX!
I just pulled the bolts from my 67 last night. Of course the Left Front nut spun with the bolt....
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
