#76 |
![]() Join Date: Jul 2012
Re: 2wd 1977 Blazer LS swap, mild drop….escalating
I’ve been looking for dry ice blasting alternative for the bottom and am thinking I am going to have to buckle down and clean this the old fashioned way with tons of elbow grease….not looking forward to that.
#77 |
Ordering another part tomorrow from a local business……
#78 |
Made some stud mounts to weld to the firewall for HVAC mounting and drilled the holes large enough for decent surface area for plug welding.
#79 |
And we had fun today, bolting parts back on the engine! Good times….
The ps return tube contacted the frame and a little downward bending resolved the interference. Mrs A.D. handled the coil and bracket refurbishment. She remounted those and the intake, torquing the bolts to spec. The AC bracket came with the VA Sure Fit….not a fan of the looks of either, so we will be going a different route on both of those components….. The sure fit items on the firewall and the ac bracket. Replacement throttle body is on the “gotta order” list too.
Doug Advanced Design’s 1977 Blazer Build Advanced Design's '48 'Burb Build Mrs Advanced Design's '72 Suburban Advanced Design's 56 BelAir LS swap Last edited by Advanced Design; 03-11-2023 at 06:37 PM. |
#80 |
Awesome build! Cool to see another truck from the Land of Lincoln.
#81 |
![]() Join Date: Mar 2011
Doug, looking good and moving along...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#82 |
![]() Join Date: Mar 2007
Hey a complete roller...Wont be long know..
Looks good. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#83 | ||
Thanks Jim! We are trying, though the trip to FL a couple weeks ago slowed us down a bit. Quote:
The new drive shaft is in. From Inland Empire in CA. |
#84 |
Seat belts were restored by TKCR, and they worked some magic on them.
Here is a before and several after pictures. The belts came out extremely nice! |
#85 |
Ran into a young man who started a pressure washing business, and he thought he could clean the floor bottoms to my liking.
He used hot high pressure water, cleansing agents and even steam to get them clean. I am thrilled with the results! Included a couple before and after pics too. |
#86 |
That's crazy, the seat belts turned out so good. That pressure was guy did a great job.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#87 |
Looking good Doug...So nice when they can come to the house. I did something similar to the bottom and interior of the suburban but with a sandblaster.
Marc
#88 |
Very cool, my favorite color combo! And the hood stripes to boot!
Just got caught up, very cool project
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
#89 |
BMW & ASE Master Certified
Pretty lucky with the high hump transmission tunnel. With the 6l80e, it wouldn't have unless its tilted down pretty far.
I wonder what the offset on those rotors is. When I did my Wilwood c-10 pro spindle with the same style caliper, I wound up using 12.915"x 30mm thick rotors from a 2006 jeep Cherokee. It does require taking it to the machine shop and having the center hub bored to fit. It was the same thickness as the NNBS brakes so it matched. clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
#90 |
What's the latest? Guessing there might be some updates. What a cool rig you found. I want to do whatever I had to do to buy a rig like that if I found it. That color combo with the '77 ochre trim? Dude! I hope you guys are having fun with it.
#91 | |
Any chance you'd like to sell the firewall cover plate that came with the Vintage Air kit? I'm doing the same thing with welded studs inside for a smooth firewall. I'm doing the bodywork now and they're estimating January delivery for the kit. I called them direct but they don't offer a digital or paper template, the firewall cover it's self is the only method they have for locating the 1/4-20 mounting bolts.
Evan B. |
#92 |
Just read through this build thread. Nice stuff going on here. Looks like this will be a great cruiser based on that very solid starting point.
#93 |
Man, that was a really cool truck you guys scooped up! Hope all is well and the build is still progressing
1985 GMC Sierra Classic Chopped down wrongbed Cammed LH6 5.3/T56/3.90 Walker Tuned 5/8 drop US Mags |
#94 |
It appears that Elvis has exited the building. I don't know Mr. AD personally and so I don't know the circumstances but it appears he hasn't been on here since last April. It's too bad, I would like to be seeing what's happening with this rig. I hope all is well.
#95 | |
And guys thanks for checking on me. I’ve been on other car and property projects…plus did some traveling and vacationing. Took too much time off from Blazer build. Helped my Grandson on rear diff for his 1998 Camaro. Enjoying life and pursuing vehicles. |
#96 |
That's Life. Good to see you're still kickin'.
#97 |
![]() Join Date: May 2015
X2..!!!!!
#98 |
Thanks guys! After a fling messing with a 1970 Cadillac and a 1996 Caprice, we sold those and picked up a clean 1996 Tahoe. Struggled with wheel stud replacement for the new wheels for the 56 with a couple days before leaving on Hot Rod Power Tour, and moved the 1949 Chevy truck my Grandpa bought new from my late Uncles barn to our shop. He used it for farming up until 1997 and it was parked. Finally we were able to get back on Garth.
Guess I kinda took a year sabbatical from trucks and I missed them! |
#99 |
We had a friend handle the seat restoration as he and his wife are wanting to do interiors as a side business. They did really well! Here are some before and after.
#100 |
Wife handled the console refurbishment. She did really well too.
| Bookmarks |
