Old 10-17-2023, 11:12 PM   #1
MS66
MS66's Avatar
Windshield wiper motor
What would cause the wiper motor in my '68 to operate in the wash mode (push button) only? Is that more common to be a switch, or motor issue?
MS66 is offline   Reply With Quote
Old 10-18-2023, 08:40 AM   #2
dmjlambert
dmjlambert's Avatar
Re: Windshield wiper motor
What are you observing that makes you ask this question? I don't see how the stock washer can work at all unless the wipers are moving, because the washer pump relies on the wiper motor movement to actually pump.
Old 10-18-2023, 08:52 AM   #3
MS66
MS66's Avatar
The wipers only move across the windshield when you hold the wash button in. The wipers do not move across the windshield in either of the two, lo/hi, operating positions.
Old 10-18-2023, 08:59 AM   #4
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
He didn't say anything about the washer working or not. I would assume from his question that the wipers only work when he pushes the switch (wash mode) and not when he twists the knob (wipers only)
My assumption would be that it's the switch but that's just a guess
67 C10 283 T5 swapped longbed fleetside = wife's daily driver(divorced)
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD(Sold)
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck(divorced)
73 El Camino SS 454 4 speed my first big block
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 10-18-2023, 09:02 AM   #5
dmjlambert
dmjlambert's Avatar
I think it is likely the switch is having problems. You would have to do some testing with a test light or multimeter to tell for sure. Here is a thread about testing. http://67-72chevytrucks.com/vboard/s...d.php?t=413551
The back of the switch is swaged to hold it together. You can probably test it when removed from the truck with an ohm meter. It has 3 lugs on it, each of which should ground to the switch case when pushed or turned to certain positions. In low speed 2 of the lugs should conduct to the case, in high speed 1 of the lugs should conduct to case, and in how or high speed pushing the button should conduct the 3rd lug to ground.
Take the switch apart and clean it up with WD-40 or DEOXIT D5. Then put it back together.
Old 10-18-2023, 10:30 AM   #6
Zeke's Garage
Zeke's Garage's Avatar
Yep, +1 on all that.
'67 Chevy Stepside
250 Inline 6
Megasquirt Fuel Injection
T5 5 speed conversion
Ferric Oxide impregnation throughout
Zeke's Garage is offline   Reply With Quote
Old 10-18-2023, 03:53 PM   #7
Rust_never_sleeps
Rust_never_sleeps's Avatar
wiring diagram here: https://67-72chevytrucks.com/vboard/...d.php?t=185856
Rust_never_sleeps is online now   Reply With Quote
Old 10-18-2023, 06:53 PM   #8
dmjlambert
dmjlambert's Avatar
I'm afraid when talking about the wiper motor circuit specifically, most of the MANY diagrams in that thread have incorrect wiring in that area. You have to go specifically to post #344 of that thread. There may be other versions in that thread having the correct wiring for wiper motor, but most are incorrect. Unfortunately it would take a huge effort to clean out all the incorrect info in that thread. Here is a link that lands on post #344:
https://67-72chevytrucks.com/vboard/...27#post9186727
Old 10-18-2023, 09:26 PM   #9
MS66
MS66's Avatar
Took the switch out of the dash socket letting it hang under the dash just enough to poke out the bottom. Fiddling with the connector and got the wipers to work with the switch grounded to metal under dash. Did this several times. Pulled the switch out, cleaned it with WD-40, cycled it several times, blew out the residue with light air pressure. Lubed it with electronics lube. Plugged it back in, touched it to ground, wipers worked as they should. Did this several times. Wipers good. I'm thinking this is good, MUCH better than fiddling around under the dash killing my back to pull the wiper motor out (just to get nowhere fast).
Replaced the wiper switch. buttoned it all up. No wipers. Back to the same drill with the washer mode pushed in only. I came inside, I'll revisit that tomorrow. Thanks for the tips, although I didn't pull it apart to make it work. It seems like it was more something to do with the spade connections on the back of it than internal contacts. I have De-Oxit and Fader lube if I need to take it apart. I'm an old electronics nut too.
Nice schematic!! Thanks.
Old 10-18-2023, 09:38 PM   #10
dmjlambert
dmjlambert's Avatar
Does your dash have new paint, particularly where the switch mounts in the hole? It's another possible thing, and pressing on the switch makes it contact ground.
Old 10-19-2023, 12:42 AM   #11
MS66
MS66's Avatar
Your assumptions are correct sir. Has nothing to do with the washer itself, just while in the wash mode. I do believe it is the switch. Will figger it out tomorrow.
No fresh paint. I'll figger it out tomorrow. Got to be something simple. I'm just proud the motor is operating. One less thing to deal with.
Old 10-19-2023, 10:12 AM   #12
MS66
MS66's Avatar
Ok, went back in there and noticed the alignment tang has something to do with grounding the switch. It had previously been in to, I saw it yesterday where it wasn't lined up just right and slightly hosed. I set the flat where it belongs in the flat in the top of the hole, tightened the 5/8 nut with an offset boxed end wrench, Voila! Grounded switch. Working like a new one for the time being. Thanks.
Old 10-19-2023, 04:26 PM   #13
Rust_never_sleeps
interesting, I didn't see either the switch or motor connected to ground on the wiring diagram :shrug:
Old 10-19-2023, 10:12 PM   #14
MS66
MS66's Avatar
Only18B at the cluster connector is grounded. I don't see the switch referenced in the schematic to see a ground, just the connector. Are you thinking these wiper switches aren't supposed to be grounded?
Old 10-19-2023, 10:23 PM   #15
LockDoc
The Older Generation
LockDoc's Avatar
If the wiper switch isn't grounded the wiper will not work....
LockDoc
Leon
Old 10-19-2023, 10:54 PM   #16
MS66
MS66's Avatar
LockDoc
Yessir, I know that. I pointed that out to the other fella, then asked if he thinks the switch isn't supposed to be grounded. Maybe I should have worded that differently. The switch is definitely grounded.
I've got my wipers all squared away now.
Thanks Leon.
Old 10-19-2023, 11:54 PM   #17
LockDoc
LockDoc's Avatar
Thanks Leon.
No problem. I just read it differently....
LockDoc
Leon
Old 10-20-2023, 01:13 AM   #18
Rust_never_sleeps
nah, clearly they are, because it runs hot to the motor, so would have to ground somewhere past the switch....and because you fixed yours that way :-D
I'm just annoyed I can't see it on the diagram
Old 10-20-2023, 10:11 AM   #19
Jason Banks
Jason Banks's Avatar
I have the exact same problem. Anyone have a theory about why it only works for the push? Does it somehow get ground that way, but not the normal way.
And then I found this thread:
https://www.67-72chevytrucks.com/vbo...d.php?t=695112
Post 15 Vette Vette is a treasure....
I had tried a new switch and that didn't fix my problem. So I thought! I took the new switch back out and put the old one in.
After reading this thread, I decided I would clean the paint off to make sure the switch was grounding and check with a meter to make sure it was grounded. It was. But still not wipers.
Dug up the new switch and reinstalled. Yay, I have wipers now!
Jason Banks is offline   Reply With Quote
Old 10-20-2023, 10:42 AM   #20
MS66
MS66's Avatar
Haha, I got ya. The only ground I see for 18B is past the cluster connector in the diagram. I'm guessing (??) that is the ground the wiper motor sees when the washer button is depressed?? Not sure. Sounds right though.
Yep, good work! There are some good guys in here that know these trucks, Leon and Vettevet are a couple of them.
Until I made sure the switch was set in the pocket just right it wouldn't ground to the dash to get the wiper motor to run in wiper mode. Someone had already been in mine before so I couldn't tell exactly how the grounding spot was supposed to look, but there was a bare spot at the flat edge at the top of the hole that made the ground. It has been a long time since I've worked on anything like this, but it almost looks like when the switch hole was punched, the flat edge was slightly raised (extruded) to guarantee a good ground there. Someone else might know more about that.
As far as the wiper working when the washer button is depressed, I believe that ground we see in the schematic at the cluster connection is why it works when the button is held in.
Old 10-20-2023, 10:59 AM   #21
Jason Banks
I really needed to clean that paint off good. My truck was a total repaint, I hadn't stripped the factory paint off the dash like I did the rest of the truck. Then it had Epoxy primer, 2k primer, base coat, 4 coats of clear.
Further exacerbating the problem was, my truck is 1968 and I changed to later style dash bezel and extended the wiper wires over to where the choke was, so the hole is not the same shape as the real wiper switch hole.
Old 10-20-2023, 11:07 AM   #22
MS66
MS66's Avatar
