Old 10-17-2023, 04:50 PM   #1
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Steering Wheel
This is a very high quality steering wheel from a 1987 Monaco motor home that used a GM tilt like the one in these trucks. It's leather wrapped and it's 18" , that makes it 1" bigger than a stock wheel. The hub adapter bolts to the steering shaft just like a GM wheel and then the wheel is bolted to the hub with 9 Allen head bolts. This uses a nice self contained horn button and spring. I'm sure the Monaco emblem could be switched for a Chevy bowtie or GMC emblem if some kind. 125.00 shipped
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 10-19-2023, 07:10 AM   #2
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Re: Steering Wheel
Is the backside clean - no abrasions??
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 10-19-2023, 03:41 PM   #3
BLAZERMAN
BLAZERMAN's Avatar
Re: Steering Wheel
Yes backside is nice, adapter hub could use repainting. The wheel could use a good cleaning.
Old 10-20-2023, 07:57 AM   #4
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Re: Steering Wheel
I would like to get this from you, install it my 70-c30. But, with all the parts in the pictures, it will bolt up to a 70 steering column head (n0n-tilt) and have a working horn button? I really don't need a $$ mistake. Inflation baby!
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
Old 10-20-2023, 10:44 AM   #5
BLAZERMAN
BLAZERMAN's Avatar
Re: Steering Wheel
David, Yes it will bolt right up to your 70 non tilt column. I'll include the horn contact with the wheel, you shouldn't need anything else to make it work. I know what you mean about "inflation", it's getting crazy!
Old 10-20-2023, 11:15 AM   #6
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Re: Steering Wheel
Sounds good, Ill take it, sent you a PM.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
