Old 10-21-2023, 12:10 AM   #4276
68bowtie
68bowtie's Avatar
Re: What did you do to your truck today.The 3rd chapter
Made a video of my big block idling. Still needs some adjustment.
https://rumble.com/v3pj0m2-1968-factory-396-swb.html
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce
Thank you all so far you are angels!!
Old 10-21-2023, 12:44 AM   #4277
pjmoreland
pjmoreland's Avatar
Attachment 2310352
Your truck sounds and looks awesome
pjmoreland is offline   Reply With Quote
Old 10-21-2023, 01:04 AM   #4278
68bowtie
68bowtie's Avatar
Thanks!
Old 10-21-2023, 04:39 AM   #4279
'68OrangeSunshine
'68OrangeSunshine's Avatar
I got my '71 GMC Jimmy back on the road in the wee small hours...
Had to call Roadside Rescue Monday night to get a guy with a jumper box.
Got home at midnight.
Back at work at 8:30 in the '68 Orange Stepside.
I had left my lights on, parked Downtown on Monday, while I was at work nearby from 12:30 to 10:30 PM. Four 5.5'' sealed beams at full blast. After work, I tried the key. Nothing. Dead flat.
Wednesday I got off early enough to drop off the Batt, a 4-y.-o. Deka
at O'RAP. A DVM reading w/o load was 12.63 vdc.
Parts store found no faults, and charged it overnight. [For free].
Stopped by Thursday and picked it up. Charged full.
While I was down, I checked the oil. It was low 1 Qt. Added one. Good catch.
Reinstalled and it cranked up good.
Ran to grocery store today.
Nominal operations resume.
Old 10-21-2023, 09:31 AM   #4280
CAMAROBOY68SS
CAMAROBOY68SS's Avatar
Attachment 2310352
sounds like how a big block should.
The Twins:
1968 C10 SWB - Blue 327/5 Speed
1968 Camaro SS/RS - Blue 327/4speed
C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278
The "Others"
1933 Ford Pickup (Camaro in disguise)
2017 Camaro SS
Life long Chevy guy
CAMAROBOY68SS is offline   Reply With Quote
Old 10-21-2023, 10:03 AM   #4281
Sheepdip
Sheepdip's Avatar
Attachment 2310352
Sounds Healthy Tim...just like it's supposed to!
Sheepdip is offline   Reply With Quote
Old 10-21-2023, 10:25 AM   #4282
67C10Step
67C10Step's Avatar
Started last night and will continue for a few days to come. Pulled the intake last night to fix a nagging and worsening oil leak on the front.
Decided to check the timing chain play before I pulled the distributor. Found that to be more than I like but not a total surprise. So, today I will drop the oil pan slightly to get the timing set out. New water pump and timing set should be here Monday.
Meantime I will clean up the heads and intake for re-install.
The little mouse motor (283) runs fine and I hope to get another year or so out of it while I save my penny’s for something else.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 10-21-2023, 05:58 PM   #4283
Nh4clo4
Nh4clo4's Avatar
Got the soundproofing, carpet and seat in!
Nh4clo4 is offline   Reply With Quote
Old 10-21-2023, 09:07 PM   #4284
'68OrangeSunshine
Took the '68 C/10 Stepside [292 L6/SM465/3.73 REAR] into AZ ADEQ [emissions]
today.
It passed.
Readings:
HC ] Hydrocarbons/PPM.....093 OF 450 allowed
CO] Carbon Monoxide %......1.82 of 5.00 maximun
Old 10-21-2023, 10:45 PM   #4285
Steeveedee
Who Changed This?
Steeveedee's Avatar
Pretty much any vehicle engine in decent shape will pass the emissions test. I worked as a state-licensed SMOG tech for years. People used to come in all concerned that they wouldn't pass. If they didn't, it was generally timing or carb adjustments, and I'd make those adjustments as required for the $25 test fee. I generally didn't even tell them I did it, just handed them the cert. Didn't take that long, and I didn't feel like charging an extra $50 (or whatever it was) for the amount of time those adjustments took. Missing equipment was a bigger deal, but those I bucked up the food chain to the BAR as required. Very seldom did a vehicle fail, really.
~Steven
Simi Valley, CA
Old 10-22-2023, 02:32 AM   #4286
'68OrangeSunshine
Then you're an angel on the ground, Pal. I've never had an ADEQ guy work on my timing or carb. On a couple of occasions, they might've let me slide or turned a blind eye to help me pass. The Compliance Certificate used to have a checklist on the back of the form listing Ignition, Carb, Timing, PCV, Gas Cap, Etc., so you could check all the boxes if you did the tune up yourself. Now the back of the form just says NOTES:
For $12.25 you get a second retest free.
My Buddy/Mechanic, Dennis would open up the Edelbrock 1404, and we'd trade out the normal running jets and metering rods, for a special set in a ziplock bag marked ''Economy'' and I 'd run thru the retest. After passing, we'd reinstall the Normal set.
I would usually do as much of a tune up as needed -- Dist Cap, Plugs, Wires, Air Cleaner, whatever else...
V8s were the worst to get thru.
The '67 K/10 Suburban w/454 has been sitting for years. The '71 Jimmy's 350 was often a Bad Boy too, but since I got YOM plates and collector car insurance, it's exempt.
L6s generally are ''Nice Kids'' to the ADEQ guys, but my 292 is bored .030-over, has a 4-bbl Edelbrock [500 CFM] Offy intake, and Clifford headers.
Anyway, year before last, I left the Economy jets and metering rods in the carb, and didn't change them out.
Last year, I passed on the first try. Just like this year.
But while I was at the emission station, I noticed my water temp get really hot. It was up past 225*F -- didn't boil over due to a 50/50 coolant mix.
[Boil-over is an immediate 'Flunk'] but I had to gradually raise my RPMs after the probes were pulled but before I got my paperwork cert. Pulling out of the facility, I cut on the Heater Air fan and Defroster to bring the engine temps down. It was in the high 90s today in Tucson. As soon as the temp gauge came back to 195* I saved the Heater etc. Engine cooled down on the way home.
I asked Dennis about this, and he said I'm set too lean, and to back off the A/F mixture screws til I get a nominal 17.5''Hg on the Manifold Vacuum gauge.
Old 10-22-2023, 09:19 AM   #4287
Steeveedee
Who Changed This?
Steeveedee's Avatar
There's plenty of money to be made in the mechanic business without stealing it. When I worked as a mechanic, the BAR's newsletters claimed that half of all repairs in California were not necessary- not just emission controls. That's probably still true. I didn't tell the boss what I did, though. He'd have gotten all soggy and hard to light. But by the time all the equipment is hooked up for the test, 3 more minutes tops for needed adjustments didn't justify the extra charge, to me.
~Steven
Simi Valley, CA
Old 10-22-2023, 09:24 AM   #4288
Jiggers72-GMC
Jiggers72-GMC's Avatar
The world needs more people like you Steven ^^^^
Gerry, North Bay Ontario
1971 Chevy K10 short stepper, 518 med green & white
1972 GMC C1500 long box, dark Brown, owned since 1977
1969 GMC C2500 manual
Jiggers72-GMC is offline   Reply With Quote
Old 10-26-2023, 04:06 PM   #4289
72c20customcamper
72c20customcamper's Avatar
Lots of crap on the 72 . First redid all the rubber lines they were real bad ended up buying them from Brake Hoses unlimited . Fit was perfect as apposed to the two other sets I bought and returned to other venders . New power vac and master only thing I had to modify the combo valve bracket to fit the original lines didn’t line up at all I had to straighten and then re-bend it I wasn’t going to change perfectly good originals . Brakes all done and bled next was the Flexplate the old one had a a few missing teeth . I took out the driveshaft and removed the crossmember bolts to the frame and replaced 4 bolts with 10 inchers and slide the trans back . Tomorrow I hope to have it buttoned up and drivable again .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 10-26-2023, 05:47 PM   #4290
LNP
72c20customcamper longer bolts is how I use to do it in the garage thru the years I wrenched for a livin. I used the long bolts to make installs easier as well.
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
Old 10-26-2023, 06:46 PM   #4291
Jiggers72-GMC
Right on Mark, glad to see you got lots done, the brake lines and all look great.
Old 10-26-2023, 07:25 PM   #4292
mr.mud1
mr.mud1's Avatar
looking good.i got the front flex hoses for my truck from Brake Hoses Unlimited in Michigan as well.as you say,fit perfect.i've been singing his praises everytime someone on here asks about brake hoses and all the aftermarket ones available at the reguular places are chinese and too short.
mr.mud1 is offline   Reply With Quote
Old 10-26-2023, 07:30 PM   #4293
72c20customcamper
Great guy to work with too . The rear line in the kit was to long he made up another to the length I wanted and sent it out . Only request was that I send back the one that didn’t fit . The rear line on the truck was 14.75 inches long the “book” calls for 18 inch .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 10-26-2023, 07:36 PM   #4294
Rust_never_sleeps
Rust_never_sleeps's Avatar
Finally got the steering gear back together. Shiny new idler arm, Pitman arm, and some 90* Zerks on the inner tie rods(cuz that's a really crappy spot for straight Zerks).
I got close Tuesday, but was fighting nausea(vertigo?) and had to give up early.
Far more pleasant all around today
Rust_never_sleeps is offline   Reply With Quote
Old 10-26-2023, 08:04 PM   #4295
mr.mud1
mr.mud1's Avatar
i ran into that with my truck,the coil spring trucks,it seems to me had the shorter hose and the leaf spring trucks got the long one or maybe i have it backwards?i do remember that differance with the length and the reason why.the hose from my Napa store for the rear was right,once we knew why the 2 different hoses but they were no help on the front hoses.
Old 10-27-2023, 08:00 AM   #4296
Danyo492
TMI seat?
Danyo492 is offline   Reply With Quote
Old 10-27-2023, 08:51 AM   #4297
72c20customcamper
Mine is a leaf spring truck . There is a bracket off the passenger side frame rail that goes over the differential the hard line runs it. The truck also has the HD leafs so that may be why . The hose they sent would have fit my coil spring truck but I had just replaced it .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 10-27-2023, 10:38 AM   #4298
maverickmk
maverickmk's Avatar
Question on the brake line routing from the master cylinder to the proportioning valve - I see that you have the rear line (closer to the firewall) routed to the front of the valve. Is the line directly below it connected to the front brakes? I am under the impression that the front port on the master cylinder is for the front brakes and the rear port for rear brakes - ? I am putting my brakes together (swapped to disks on the front) and if yours is correct then I need to reroute some lines.
Die with memories, not dreams.
Not to brag, but I don't need alcohol to make really bad decisions.
1969 GMC Short Step Side
maverickmk is offline   Reply With Quote
Old 10-27-2023, 06:23 PM   #4299
72c20customcamper
This is the complete set up from Franks Pickmup . My original master was routed the same way. The larger reservoir(rear) is for the disc so as they wear the fluid will go down so you need a larger reservoir and yes the front line from the valve bottom is for the front brake . Rears are self adjusting so no drop in fluid
https://67-72chevytrucks.com/vboard/...d.php?t=581862
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 10-27-2023, 08:18 PM   #4300
maverickmk
maverickmk's Avatar
Gotcha', thanks!
