10-25-2023, 02:08 PM | #1 |
Auto column parts questions
Hello all! I have a few questions. Do any of the parts suppliers make the original type linkage and brackets for a 64 - 66 C10 with a factory auto on the column. I have the original column but I am missing all the other components. Secondly was the original powerglide a long or short tail-shaft?
Thanks |
10-26-2023, 10:12 AM | #2 |
Re: Auto column parts questions
There's several different styles of linkage used from 63-66 so if you want exact , need to be more specific , it has to do with the frame bracket mainly but any 64-66 linkage will work. 67-70 PG linkage will work as well. The PowerGlide cross shaft is unique to that transmission so TH400 linkage is different. All powerglides of this era are short shaft .
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
10-26-2023, 12:32 PM | #3 |
Thanks for the response...the column is out of a 66 C20 and will be installing in a 66 C10. Not sure what the transmission is out of, possibly a 63 car. Is there aftermarket linkage available that anybody may know of? I have seen aftermarket kits that require changing the shifter shaft so that may be an option.
10-26-2023, 02:29 PM | #4 |
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
10-27-2023, 02:15 AM | #5 |
Or you can save $60.00 bu getting this Lokar knock off for $30.00 on eBay. That's what I did.
https://www.ebay.com/itm/35467667808...Bk9SR5L0kPztYg |
10-27-2023, 01:05 PM | #6 |
Thanks all for the info, but not sure these will work with the powerglide as the shifter shaft is welded on.
