Old 10-27-2023, 08:56 PM   #4301
CAMAROBOY68SS
CAMAROBOY68SS's Avatar
Re: What did you do to your truck today.The 3rd chapter
Started pulling the motor out of the truck today. Got the 4 speed out and got prepped to yank the motor tomorrow. Then onto detailing the engine bay again and getting the new 327 and 5 speed prepped.
The Twins:
1968 C10 SWB - Blue 327/5 Speed
1968 Camaro SS/RS - Blue 327/4speed
C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278
The "Others"
1933 Ford Pickup (Camaro in disguise)
2017 Camaro SS
Life long Chevy guy
CAMAROBOY68SS is offline   Reply With Quote
Old 10-27-2023, 09:04 PM   #4302
pjmoreland
pjmoreland's Avatar
Alright!!
pjmoreland is offline   Reply With Quote
Old 10-27-2023, 09:38 PM   #4303
samkost
samkost's Avatar
I just spent the last several minutes staring ………………….at your truck.
“Staring”
Staring is a prolonged gaze or fixed look.
In staring, one object or person is the continual focus of visual interest, for an amount of time“
That’s one sharp object.
Sam
1972 C10 LWB
2020 Z71 Tahoe
samkost is offline   Reply With Quote
Old 10-28-2023, 10:06 PM   #4304
CAMAROBOY68SS
Got the 350 out today and cleaned a few things up and now moving onto swapping stuff over to the 327 and doing some measurements for the new TKX 5 speed.
The Twins:
The "Others"
2017 Camaro SS
Life long Chevy guy
Old 10-29-2023, 12:21 AM   #4305
'68OrangeSunshine
'68OrangeSunshine's Avatar
I love them Orange color engines
Old 10-29-2023, 08:50 AM   #4306
Jiggers72-GMC
Jiggers72-GMC's Avatar
Great work Cboy, that's the first time I see a ballast resister on these trucks ...........
Gerry, North Bay Ontario
1971 Chevy K10 short stepper, 518 med green & white
1972 GMC C1500 long box, dark Brown, owned since 1977
1969 GMC C2500 manual
Jiggers72-GMC is offline   Reply With Quote
Old 10-29-2023, 09:02 AM   #4307
tim_mc
tim_mc's Avatar
Nice to see the progress on your '68 - beautiful truck. Small project for me yesterday. I swapped out my OEM-style starter to a Powermaster 9112 hoping to solve a heat soak issue. Wow - wish I would have gone with a high torque starter sooner. Keep the pics coming!
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column.
tim_mc is offline   Reply With Quote
Old 10-29-2023, 10:15 AM   #4308
CAMAROBOY68SS
Its there because I un converted the truck from HEI back to points. The previous owner put HEI in and cut the original resistance wire out of the harness. So the resistor is there to be the replacement. Ive been looking locally for a old harness that someone ripped out to just get that wire to swap back in and remove the ballast but no luck so far.
The Twins:
The "Others"
2017 Camaro SS
Life long Chevy guy
Old 10-29-2023, 01:19 PM   #4309
LNP
You can buy resistor wire and just put it back in the harness. Just look for automotive ignition resistor wire.
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
Old 10-30-2023, 02:48 PM   #4310
67C10Step
67C10Step's Avatar
I removed the resistor wire from my 67 all the way back and removed the connector from the bulkhead. One would only have to snap it back in and, knowing me, it is probably coiled up and stashed on one of my boxes of truck stuff. I'd be happy to dig it out if you want it.
I am finishing up an intake reseal, new radiator, new timing gear/chain set, and new alternator install. This photo was before I pulled the carb apart, gave it a run through the ultrasonic cleaner, and reinstalled. Now I have a fuel leak at the fuel pump that I guess monkeying around with the fuel line caused. This is the fun stuff right?
Still need to repaint the oil filler cap as now it stands out with everything else cleaned up.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 10-31-2023, 06:18 PM   #4311
Rust_never_sleeps
Rust_never_sleeps's Avatar
New rear shocks. OEM Spectrum, nothing fancy. For once, things went pretty much as expected ;-)
Spec is for 75#, but there is no way the existing ones were nearly that tight. :shrug:
Rust_never_sleeps is offline   Reply With Quote
Old 11-04-2023, 10:05 AM   #4312
CAMAROBOY68SS
Yeah I would be interested in that wire if you still got it. Just shoot me a message if you still got it.
The Twins:
The "Others"
2017 Camaro SS
Life long Chevy guy
Old 11-04-2023, 10:13 AM   #4313
CAMAROBOY68SS
Making some more progress. Got the offset dowel pins in and the got the final runout ran and all set for the tremec. Then got the new clutch installed.
Also this past week got all the stuff being moved over from the 350 to the 327. Just a little more cleanup in the engine bay and this motor will be ready to drop back in to the truck.
The Twins:
The "Others"
2017 Camaro SS
Life long Chevy guy
Old 11-04-2023, 06:32 PM   #4314
TxGary
TxGary's Avatar
Installed the TC boot ring retainer that I bought from board member A1971Blazer. Very nice piece.
71 C-10 SWB
1969 C-30 Custom Camper Motorhome Restoration in progress.
2020 Chevy 2500 Crew 4x4 LTZ Diesel
2024 Chevy Tahoe Z71 4X4
2015 Diamond C 22' HD car hauler
Bowie, Texas 76230
TxGary is online now   Reply With Quote
Old 11-04-2023, 07:27 PM   #4315
'68OrangeSunshine
Nice. But does he do one with GMC instead of the Bowtie?
Asking for a friend with a Jimmy.
Old 11-04-2023, 07:58 PM   #4316
3757chevy
3757chevy's Avatar
Very nice .
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 11-04-2023, 08:19 PM   #4317
TxGary
TxGary's Avatar
Yes, he has them posted under blazer & suburban stuff.
71 C-10 SWB
Bowie, Texas 76230
Old 11-04-2023, 08:40 PM   #4318
'68OrangeSunshine
Cool. Thanks.
Old 11-05-2023, 09:26 PM   #4319
CAMAROBOY68SS
Got the 327 back into the truck today. Now to start getting the tremec fitted and everything back onto the motor. Another week or two and it should be running again.
The Twins:
The "Others"
2017 Camaro SS
Life long Chevy guy
Old 11-05-2023, 10:02 PM   #4320
Extended Power
Extended Power's Avatar
Making headway on more wiring.
Electric fans, Lokar kick down, MSD-6AL2, Vintage Air, and MSD HVC II coil all wired up.
Sorry, no idea how to flip picture.
"If it ain't broken, fix it 'till it is!"
Extended Power is offline   Reply With Quote
Old 11-05-2023, 10:10 PM   #4321
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
I do, so Flipped!
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
Old 11-05-2023, 10:27 PM   #4322
Extended Power
Originally Posted by Rich72C10 View Post
I do, so Flipped!
Thank you!
Old 11-05-2023, 11:36 PM   #4323
allchevy58
allchevy58's Avatar
Last Monday had LineX sprayed in the bed.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 11-06-2023, 08:21 AM   #4324
Jiggers72-GMC
Nice job on the Line-ex, great work truckers
Old 11-07-2023, 12:07 AM   #4325
3757chevy
3757chevy's Avatar
Very nice . Good job on color match.
MIKE
