Old 10-29-2023, 03:43 PM   #1
vardenafil
Tallest tire possible on stock steel rims?
I have a 72 k20 with a 4 inch lift. I would like to keep the classic steel rim look on my truck. The truck currently has 7.5 16t lt tires on it which is almost 32 inches tall. I would like to get tires a little taller close to 35 inches if possible. The guy at discount tires tells me I need new rims to get to 35 inches. Is there a tall skinny tire that will fit our stock steel rims?
vardenafil is offline   Reply With Quote
Old 10-29-2023, 04:52 PM   #2
jocko
jocko's Avatar
Re: Tallest tire possible on stock steel rims?
I'm not aware of anything that fits a stock-ish (i.e. relatively narrow) 16" truck steel wheel that can get you to 35, but others may know of some options. 255/85/16 is the tallest tire I've seen that can be safely mounted on a 6.5-8" steelie - just over 33". How wide are your wheels, inner lip to inner lip? that may help narrow down (or expand) your options.
Old 10-29-2023, 04:58 PM   #3
HO455
HO455's Avatar
There are lots of choices for 16 inch rims. The problem may be your current rims may be too narrow for a taller wheel especially if you want to stay with a radial tire.
https://www.4wheelparts.com/b/tires-...gories%7Ctires
What rims are you wanting to use?
RIP Bob Parks.
Old 10-29-2023, 06:39 PM   #4
vardenafil
I was wanting to use the stock rims. But I have my eye on some ion or pro comps in case I can’t go big on stock rims
Old 10-29-2023, 07:07 PM   #5
Sicklajoie
The Niner
Sicklajoie's Avatar
Pretty sure that 255/85/16 at 33" tall is the tallest you can go on a 16 x 7 rim. Anything taller than that would need to go 8" wide.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 10-29-2023, 07:13 PM   #6
roboticjunky
Here's 3 tires I found that might work.
This is a military style tire and would need a tube inside of it.
https://www.summitracing.com/parts/cok-71025
These other 2 are more what you're wanting.
https://www.summitracing.com/parts/ict-sam-53
https://www.summitracing.com/parts/ict-ssr-41r
roboticjunky is offline   Reply With Quote
Old 10-29-2023, 07:51 PM   #7
jocko
jocko's Avatar
nice finds roboticjunky!
Old 10-30-2023, 09:26 PM   #8
MS66
MS66's Avatar
Back in the day we would run 9.00 x 16s. Those were the equivalent size of a Q78 x 15, which was listed as 36.4 tall. Long gone are those tires, but here is a set from Coker tire, listed as Super Lug, 36.3 tall.
https://www.cokertire.com/tires/sta-...ly-900-16.html
Here's another 9.00 x 16 tire listed. These are listed to fit a 6.5 x 16 rim size.
https://www.stausaonline.com/tires/sta-super-traxion/
Both tires will fit a 5 - 6.5" wide rim.
MS66 is offline   Reply With Quote
Old 10-31-2023, 12:12 PM   #9
factorystock
factorystock's Avatar
The 9.00-16 is that tire if you already have a lift for clearance. Has the tread pattern of the more common old school 7.50-16 that was very popular at one time.https://www.ebay.com/itm/33479329762...Bk9SR7Sl5OfwYg
factorystock is offline   Reply With Quote
Old 11-01-2023, 07:11 PM   #10
vardenafil
i only have a 4 inch lift on the truck. im not sure the 36 inch tires will fit. i might have to stick with the 33's or just swap out the rims.
Old 11-01-2023, 07:22 PM   #11
Louisvillekytruck
Great looking tire
Louisvillekytruck is offline   Reply With Quote
Old 11-01-2023, 07:38 PM   #12
MS66
MS66's Avatar
9.00/16 should fit with 4" lift
Old 11-01-2023, 07:47 PM   #13
vardenafil
thanks everyone for the suggestions. im gonna see what deals i can find for some tires.
Old 11-01-2023, 09:17 PM   #14
Louisvillekytruck
Do u have any pics of your truck
Old 11-01-2023, 10:12 PM   #15
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
33's will fit with no lift so you should be golden.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 11-01-2023, 11:21 PM   #16
Richard
Tire fitment is about clearance. With the skinny tire, rim and stock backspace there may be no issues while turning? If the tire does not fit in the wheel opening at full bottom the bump stops need to be lowered. For many that have pavement pounders (fine by me) clearance while turning at full bump is not really an issue.
Richard
Old 11-02-2023, 06:00 PM   #17
bnorth
You can occasionally find a 9.00R16 Michelin military surplus tire. I ran a set on a first gen Cummins Dodge I had around 15 years ago. They are the XL tread pattern.
1970 C10 l/b 292/4spd
Build: http://67-72chevytrucks.com/vboard/s...d.php?t=811062
bnorth is offline   Reply With Quote
