Old 10-14-2023, 07:08 AM   #1
Gary 70 Jimmy
Gary 70 Jimmy's Avatar
Question about brake lines
Have a 70 jimmy need to no if it takes one brass washer or 2 .
One on both sides of the t connection.
1972 GMC Jimmy 1/2 4X4 4wheel camper
1970 GMC Jimmy 1/2 4X4 350
1969 Chevy Blazer 1/2 4X4 307
1967 chevy LWB 3/4 396
Gary 70 Jimmy is offline   Reply With Quote
Old 10-14-2023, 03:12 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Question about brake lines
It should have one on each side. They are actually copper.
What are you connecting the "T" to?
LockDoc
Leon
Old 10-14-2023, 03:35 PM   #3
Steeveedee
Who Changed This?
Steeveedee's Avatar
I'm used to seeing washers on AN lines, not on lines with a double flare. Am I missing something?
~Steven
Simi Valley, CA
Old 10-14-2023, 05:57 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I'm confused too. This is out of my area of expertise (as if I had one!). I assumed it would be a flared fitting with no washer.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 10-14-2023, 07:27 PM   #5
A1971Blazer
A1971Blazer's Avatar
center bolt looks like it might be a banjo....which they don't usually have...unusual for a brake line T
if it is, it does need copper washers...
the lines are flared fittings, no washers needed
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 10-14-2023, 07:58 PM   #6
CKfan
Looks just like mine.
I replaced mine exactly like it came off. Whether it was right in the first place?? It works
CKfan is offline   Reply With Quote
Old 10-14-2023, 08:40 PM   #7
LockDoc
LockDoc's Avatar
I could see that the large center bolt was a banjo style bolt so That's why I answered the way I did. I have never seen that setup either, that is why I asked about it. Thanks for the pictures CKfan.
LockDoc
Leon
Old 10-15-2023, 02:31 PM   #8
Gary 70 Jimmy
You only used the one brass washer.
Old 10-15-2023, 04:57 PM   #9
CKfan
If I remember correctly, it was one copper washer on each side of the block but I can't be sure. I already deleted my disassembly pictures
Old 10-15-2023, 09:48 PM   #10
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
I haven't ever seen that fitting on any truck! A union with a banjo bolt to the frame? Whats on the other side of the frame? Have a pic? A banjo bolt feeds something via a hole through the length of the bolt... What's on the other side?
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 10-16-2023, 02:53 PM   #11
CKfan
#6 in thread
Old 10-16-2023, 03:20 PM   #12
CKfan
Gary 70 Jimmy and my 69 chevy K10 have the same D/S union (banjo?) to front brake line setup. I also have a 70 K10 with the same set up.
I am no brake line expert, I just put them back like I found them if they worked in the first place and can Not say for certain if they are factory but it would be one heck of a coincidence.
Old 10-16-2023, 04:25 PM   #13
palallin
CKfan, my K10 is set up just like yours.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 10-19-2023, 10:10 AM   #14
Gary 70 Jimmy
Put the washers on both sides.
Old 10-20-2023, 01:08 AM   #15
Gillnetter
Gillnetter's Avatar
I have the same set up on my 70 k10. I am adding 72 front discs and the front flex brake lines will not connect to this. Anyone know if there is an adapter available?
1972 Blazer CST Dark Olive, am/fm, tilt, tow hooks, tach dash
1972 SWB C-10 Highlander Blue/White
1972 Canadian 2wd Jimmy light olive
1970 SWB 4x4 4 speed 307
Gillnetter is offline   Reply With Quote
Old 10-21-2023, 07:17 AM   #16
Gary 70 Jimmy
The holes in the frame are in a different spot on the 1971 I had that problem when I got a 1971 frame for my 1970 jimmy. Bought all new stainless steel brake lines for 1970 before I realized the holes in the frame.
Old 10-21-2023, 01:09 PM   #17
Gillnetter
Gillnetter's Avatar
Thanks for the reply. Thought someone would make an adapter to join the two. In-line tube makes a front brake line kit for a 71. Might have to try that and drill a couple holes.
Old 10-21-2023, 01:13 PM   #18
HO455
HO455's Avatar
Interesting. I learned something new today.
RIP Bob Parks.
Old 10-22-2023, 04:56 PM   #19
CKfan
I now wish I didn't do this, but I pulled the banjo apart because I noticed I had placed the nut that holds the D/S brake hose to the frame on the wrong side (outside instead of on inside where it goes). The clip goes on the outside which I did not have in place. If I get this back together without a leak I will be shocked!
Pictured is how the banjo is assembled properly.
Old 10-22-2023, 05:29 PM   #20
Steeveedee
Who Changed This?
Steeveedee's Avatar
Oh-Ho! I was thinking copper washers for the flared seats. My mistake. I learned something, too.
~Steven
Simi Valley, CA
Old 10-22-2023, 06:18 PM   #21
CKfan
All back together leak free. Thank goodness Napa was open till 3 today and had copper washers.
I have learned in the past, never re-use them, it will come back to bite you sometimes.
I hope this helps someone as I rarely see these "banjo" connections and hope I don't have many in my future.
Old 10-23-2023, 08:17 AM   #22
Gary 70 Jimmy
I am sure I will have some leaks put all new brake lines on mine.
Nice picture of how it goes together.
Old 10-23-2023, 08:31 AM   #23
Gary 70 Jimmy
If you buy 71 brake lines they come with a return line that's not on your 1970 and the brake lines on the back axle come down front the bottom of the bed. Their are more thing that are different. Maybe you can just get the front ones that go thru the frame on the back side of front the axle.
Old 10-29-2023, 08:38 PM   #24
Gillnetter
Gillnetter's Avatar
Searched everywhere could not find an adapter. Ordered new brake lines. Probably a good idea to swap them all out anyways.
Old 10-30-2023, 08:20 AM   #25
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Question about brake lines
I put 1972 brake lines on my 1970. Very little was even remotely similar. Fortunately, I have a 1972 frame that supplied all of the brackets, fittings and showed proper placement. I used the 1970 style red frame clips from the front to back line that are also shared the fuel line.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
1970cstblazer is online now   Reply With Quote
