10-31-2023, 09:39 AM | #1 |
Clutch Pedal Stripped Splines
Where can a guy get a new clutch pedal and clamp for the splines to master cyclinder push rod ?
My original pedal has some stripped splines, the clamp was loose and started slipping. Now I cannot make the clamp tight enough to eliminate the slipping I have not been able to find a vendor that sales the pedal and clamp
48 CJ2A 63 1500 GMC (LS1 w/ Muncie 4spd) 68 RS Camaro 71 K20 BBC & granny 4 speed 95 2500 4x4 17 HD2500 4x4 Want => 67 C10 short bed w/ Manual Tranny |
10-31-2023, 06:57 PM | #2 |
Re: Clutch Pedal Stripped Splines
With so many automatics having been installed in recent years I would think a used one to be do-able.
Like this: https://www.ebay.com/itm/26647304372...IaApBhEALw_wcB |
10-31-2023, 07:20 PM | #3 |
Moderator
Find your local place that rebuilds FWD axle shafts. They will put spray weld on it, and re-machine the splines.
10-31-2023, 08:03 PM | #4 |
Aspen Auto in Arizona May have those. They are a dismantled specializing in old Chevy trucks.
10-31-2023, 10:28 PM | #5 |
The whole truck is used, good used parts are great !
I have not been on EBAY in years, thought EBAY disappeared with floppy disk Thanks
