Old 11-04-2023, 07:23 AM   #1
Rich1972C20
Mysterious Pilot Bearing Piece
I separated a 1972 SM465 from my 350 and the piece circled in the photo fell out (at least it was on the floor beneath the transmission when I removed the transmission). It fits perfectly into the throwout bearing.
I don't see this piece on any website and I don't know why the center is slotted (the input shaft is round).
Any clue what it is? I never did clutch replacement and I'm trying not to screw it up.
Rich
Rich1972C20 is offline   Reply With Quote
Old 11-04-2023, 01:31 PM   #2
kwmech
Re: Mysterious Pilot Bearing Piece
Never seen anything like it. Some clown at the factory maybe.
Old 11-04-2023, 03:28 PM   #3
Wrenchbender Ret
I,ve done a lot of them & have never seen that part before.
George
Wrenchbender Ret is offline   Reply With Quote
Old 11-04-2023, 03:54 PM   #4
sixty8HDC30
Spacer?
____________________________________
sixty8HDC30 is offline   Reply With Quote
Old 11-04-2023, 04:17 PM   #5
ratty69
Could that be from the Z bar?
ratty69 is offline   Reply With Quote
Old 11-04-2023, 07:01 PM   #6
Accelo
Accelo's Avatar
Is it a piece from a 4 speed transmission where the shifter enters the case?
Accelo is offline   Reply With Quote
Old 11-04-2023, 08:34 PM   #7
Steeveedee
Who Changed This?
Steeveedee's Avatar
I couldn't tell you how many clutches I've replaced (many dozens as a guess), but I don't ever remember seeing one of those things.
~Steven
Simi Valley, CA
Old 11-04-2023, 09:18 PM   #8
'68OrangeSunshine
'68OrangeSunshine's Avatar
Yeah. I think it's the top of the shifter ball that's under the twist-to-lock tin shifter cap. How it popped out is a mystery.
And if you already have one, it could be that a PO or his mechanic couldn't find it on reassembly, so they got another one to replace it. When you pulled the transmission, you ''found'' it. Where it lodged in the interim is another mystery.
Just a guess,but it is not part of the pilot bearing, trans spline, throw-out bearing, or Z-Bar assemblies.
Old 11-05-2023, 09:48 AM   #9
Rich1972C20
I was excited that it might be for the shifter ball but it isn't. It fits in but the slot in the peace is not big enough to allow the shifter linkage to go down into the transmission.
I just find it strange that it perfectly matches the throwout bearing (see photo) but it doesn't go there. From your guys responses and manuals I feel pretty confident that it not part of the transmission. I did have the whole tranny inspected and cleaned after I took it out and the mechanic didn't mention anything.
If I find out anything new I'll let you guys know.
Old 11-05-2023, 11:23 AM   #10
Getter-Done
Getter-Done's Avatar
Kinda looks like a lawnmower part to me.
A spacer for the spindles and blade?
The early bird gets the worm,
84 Chevy K-20
Old 11-05-2023, 01:08 PM   #11
CKfan
Funny, looks like the bottom spacer on my 4" angle grinder.
My milwaukee circular saw has a piece like that also that locks the blade in place.
That is an odd one.
CKfan is offline   Reply With Quote
Old 11-05-2023, 01:15 PM   #12
CKfan
Yep, lock washer to a circular saw
Old 11-05-2023, 02:03 PM   #13
Steeveedee
Who Changed This?
Steeveedee's Avatar
Son of a gun! I even have and use circular saws!
~Steven
Simi Valley, CA
Old 11-05-2023, 02:14 PM   #14
Getter-Done
CKfan I think you have solved the mystery
84 Chevy K-20
