Old 11-05-2023, 02:41 PM   #1
Beach-Burban
Beach-Burban's Avatar
New Gas Cap has me confused?
Recently installed Edelbrock Pro Flo 4 EFI and Fuel Sump Pump to my ‘72 Suburban, which calls for a vented fuel system. I removed the charcoal canister and utilized the factory vent line that went to it (as suggested by Edelbrock) and replaced the factory “Vacuum Pressure” gas cap with a “Vented” cap…but there is still a noticeable “whoosh” sound when I remove the cap after driving it? Am I overlooking something? Any advice would be appreciated.
Woody
Beach-Burban is offline   Reply With Quote
Old 11-05-2023, 03:04 PM   #2
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: New Gas Cap has me confused?
My 72 did that once or twice, with a new cap. I replaced it with one of these. Same was on my 71 with the vapor can removed.
What does Edelbrock say to do with the vent line?
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 11-05-2023, 08:47 PM   #3
Beach-Burban
Thanks for the response, Tony…this never happen when the canister was hooked up (even when using the factory “Vacuum Pressure” cap?), but it was a QJet then. Edelbrock said to run the vent hose from their Fuel Sump Pump directly to the hardline that the canister used to run to (located down on the frame, close to the radiator). They call it a “vent”, and specifically say that a “return” is not required.
Woody
