Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 11-05-2023, 03:56 PM   #13
KFF 1
KFF 1's Avatar
Re: New project : 72 Suburban
Well, I went out to the garage Monday after work and to my surprise the bolt circle on the new converter was wrong. So, Thursday after work I pulled the short block back out, boxed up the converter and went to Summit after work Friday to exchange converters. Yesterday while the short block was out I installed the lifter and trays, timing chain and cover, plus the oil pan then put it back in and bolted it back up to the transmission. This morning I bolted up the converter and installed the AC compressor back in the bracket then cleaned up the bench to make room for the heads and intake which should be finished this week. Not sure if I will have it running next weekend but it will be close, if not no big deal.
KFF 1 is offline   Reply With Quote
