Old 11-03-2023, 09:51 PM   #1
BuffDrinkLots
Strange Transmission Leak/Crack
Hey all, looking for advice. I have a TH350 in a 1972 C10, Automatic. There is fluid leaking from above the pan, in the case. It’s coming out of the hole (I think it’s a hole) that I circled in the picture. I am not sure what this part of transmission does. Is it a vent? Can I just try plugging it up? Thank you guys!
BuffDrinkLots is offline   Reply With Quote
Old 11-04-2023, 11:33 PM   #2
Myself
Re: Strange Transmission Leak/Crack
I don't recall there being a hole there in the few I've rebuilt. BUT, the servo cover is also right there. You sure it's not spitting out of that cover and OVER towards that hole?
Myself is offline   Reply With Quote
Old 11-05-2023, 11:39 AM   #3
BuffDrinkLots
Thanks for the reply, I am sure. It leaks while it just sitting. That servo cover area is dry. Just wet coming out of that circled area. It drips onto the pan and down. Thought it was the pan, at first. Might just try some RapidFix/Quick Steel combo if it isn’t some vent or something. Just wasn’t sure, I thought the vent was always toward the top of transmission.
Old 11-05-2023, 12:19 PM   #4
Accelo
Accelo's Avatar
This is the hole the park pawl pin is in.
It's possible it was damaged when the vehicle was put into park while moving?
Or the plug is missing is missing or damaged. The plug is on the side next to the governor. You can removed the governor cover with a screwdriver and an hammer to get a better look.
cheers
Accelo is offline   Reply With Quote
Old 11-05-2023, 01:34 PM   #5
HotWheelsFan
HotWheelsFan's Avatar
Yes, a dowel which the parking pawl uses as the pivot is the area you have circled. I think it's a press fitted part, anyhow if there is a plug (such as a small freeze plug looking) it can be repaired/replaced or resealed. This would not be a fluid under pressure area. The case may be cracked?
Bob
HotWheelsFan is offline   Reply With Quote
Old 11-05-2023, 03:09 PM   #6
LNP
If you clean it out real good with brake cleaner and make sure theres no big globs of grease in there you can just fill it with JB Weld. This way It can be drilled out later. Or possibly use silicone sealer.
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
Old 11-07-2023, 08:34 PM   #7
BuffDrinkLots
Thank you all for the responses! I’m going to try cleaning and sealing it, and see if the leak stops or slows. This is the best forum around for a reason.
Old 11-08-2023, 01:03 AM   #8
geezer#99
geezer#99's Avatar
I’d check the vent is clean first.
geezer#99 is online now   Reply With Quote
