Old 11-08-2023, 03:11 PM   #26
jwilson645
Re: Pawpaw's 55 GMC.......my new project
Originally Posted by daveshilling View Post
That IS an option I'm looking at if necessary. I'm working on a few different things this week. week.
These would work and are what I based my template off of but they're on backorder.
https://www.speedwaymotors.com/Basic...ckup,7688.html
Since I changed jobs, I don't have access to the steel supplier I used to use. He has some 3/8" drops but is over an hr away from me now so I can't just run there at lunch. The area I'm in doesn't have any suppliers.
jwilson645 is online now   Reply With Quote
Old 11-09-2023, 02:03 AM   #27
dsraven
do you have a high school in the area with a metal shop? sometimes the teacher will give kids a project like that to learn skills with a torch or whatever. they could cut it out for you, learn a thing ot two and you get a cheap (likely) part that you can finish yourself.
send the cut pattern biggger than you need, lol.
Old 11-27-2023, 04:26 PM   #28
jwilson645
Well I got my 3/8" plate and cut the brackets out. Not happy with them. These are straight pieces and to use the 3/8, they really need a bend in them for the caliper. The inside pad won't fit between the rotor and bracket without grinding. I currently have the bracket ground down to 5/16" so that the pad fits but it still needs more so the pad doesn't ride against the rotor so much.
The 15x6 wheel is also rubbing the caliper even with the 3/16 spacer. Have to grind there too and maybe up the spacer. I won't do that though until I resolve the bracket issue.
Old 11-27-2023, 06:02 PM   #29
daveshilling
daveshilling's Avatar
I took measurements of the correct brackets that come with the 6 lug disc kits, I'll try to find and post
daveshilling is offline   Reply With Quote
Old 11-28-2023, 08:32 AM   #30
jwilson645
That would be great, thanks!
Old 11-28-2023, 01:49 PM   #31
57tailgater
A couple of comments:
1) The 6 lug kits are designed using later model square body caliper and rotor hats for 16" wheels. If you are using 15" wheels, you need to make sure they are designed for disc brakes (yes there are differences) and clear the calipers. There may also be a need for a thicker wheel spacer.
2) That bracket you are working on, note in the kits there is an offset in the bracket which offsets the caliper mounting further inboard a little. Again for wheel clearance.
3) The 5 lug kits have early 70's Camaro components which work with the 15" wheels better.
57tailgater is offline   Reply With Quote
Old 11-28-2023, 02:35 PM   #32
jwilson645
I appreciate the info. I have 78 k10 rotors mounted on my original hubs(with roller bearing conversion) and 72 c10 calipers and test fitting 15x6 wheel vintiques series 62 with 4" bs. https://www.summitracing.com/parts/wvi-62-5606334
A 15" wheel SHOULD clear. I just need to find the right one or use a larger spacer. I know 3/8" will do it but then that will need longer wheel studs. I'd like to stay at 1/4" or less. I can grind some off the corner of the caliper since it isn't rubbing much. I just have to iron out the bracket issue. I will probably just go ahead and order these https://www.speedwaymotors.com/Weld-...cket,3348.htmland build them the way that they were done in this thread https://67-72chevytrucks.com/vboard/...d.php?t=797504 since this is where I got the rotor and caliper info to begin with.
Old 12-02-2023, 10:33 AM   #33
Jason 56
Looking good! Looks to be a good starting point. I’ll be following
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build
Jason 56 is offline   Reply With Quote
Old 12-11-2023, 10:45 AM   #34
jwilson645
While it was raining Saturday, I managed to get the driver side fender patched. Both have rust though along the edge where the brace is on the back side. You can see in previous picture that one had had filler put over the rust holes. All that was ground out and I did some hammer & dolly work to straighten the dents so it'll only need a skim coat not instead of the 1/4" thick stuff that was on there.
Old 12-11-2023, 10:47 AM   #35
dsraven
did you also need to replace part of the inner rear brace as well? mine has the same issue but im not there yet.
Old 12-11-2023, 11:05 AM   #36
jwilson645
I did. The brace was only brazed on in 2 spots, the top and bottom. The rest was simply held on by the folded over fender edge.
Old 12-11-2023, 11:06 AM   #37
jwilson645
Old 12-11-2023, 11:17 AM   #38
dsraven
have you ever tried a shrinking disc for the final metalworking after the hammer and dolly? they work great. basically, they hit the high spots only and heat them up from friction, then you use a wet rag to cool those spots down fast and the shrink, levelling the surface. onlt needs to get hot enough to cause a little steam when the wet rag is rubbed accross. some have used a fabric iron for the same theoretical purpose. there are videos on youtube. wray shelen (? spelling) sells a good one and also has a video.
Old 12-12-2023, 10:09 AM   #39
jwilson645
I have not tried one, although I've seen Wray's videos before. I watched some of Carl Fisher's (Make It Kustom/ Jap Hands Kustoms) videos this morning on the hammer & dollying since it's been quite a while. He's good at explaining g and demonstrating if you haven't watched him on YT before.
Old 12-12-2023, 10:12 AM   #40
dsraven
yup, I have seen make it custom's stuff. always good ideas and shows how to get stuff done without buying a garage full of spendy tools.
Old 12-12-2023, 10:14 AM   #41
dsraven
I have the shelen disc kit with the larger and smaller discs. they work great for the final metalworking. a slapper also helps, I made one from a piece of leaf spring i found on the road a few winters ago. Calgary has such smooth infrastructure, NOT!
Old 12-12-2023, 10:16 AM   #42
dsraven
sometimes the slapper gets used as a dolly as well, depending on the profile needed.
Old 04-15-2024, 07:39 PM   #43
jwilson645
Front discs and steering are together. Started mounting the Blazer tank yesterday.
