Old 11-08-2023, 11:20 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: 67 SWB First Build
Real nice build. Sure takes a while don't it? I started mine in 2015. I'm in well over a year for a front bumper and seat, they're still pending. Since covid, things have proved very difficult to have done, and right.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 11-15-2023, 02:12 AM   #2
Scurry67
Appreciate the compliment. Definitely has taken some time. I’m definitely motivated to make some more progress after an 8 month hiatus.
I’m dreading the wait time on my seat upholstery. I’ll find that out this December I’m thinking. By the way, i really enjoy your build. I’ve stayed caught up on it for awhile now. It’s been very informational!
67 SWB First Build
http://67-72chevytrucks.com/vboard/s...d.php?t=777171
Scurry67 is offline   Reply With Quote
Old 11-15-2023, 02:26 AM   #3
Scurry67
Taking a little break from the buffing. I felt like switching it up a little bit. I hung the inner fenders a couple nights ago. Very minor scratches I’ll have to clean up at some point.
I also decided to break out the new wiring harness. Every time i looked at it, i’d get intimidated and find something else to do. I finally decided to jump into it though. I’ve been taking small bites out of it every night i get up to the shop. It seems to be progressing and is less intimidating now.
67 SWB First Build
Old 12-01-2023, 03:17 AM   #4
Scurry67
I’ve been making some progress on the wiring as time permits. I made a good start on the interior but ran into an issue with mounting the vintage air evaporator. I smoothed my firewall early on without considering how to secure the evaporator to the firewall. I think i have a solution but put it on hold. I jumped into the rear harness and was able to get it routed along the frame rail to the rear of the truck. I used the ebrake firewall hole to exit the cab since i don’t plan on installing an ebrake.
Another issue i had was i didn’t consider the taillight housing when moving my filler hose up the rear stake pocket. In order to get it to sit flush, i had to modify the terminal location. It came out pretty decent.
Lastly, i installed my taillights. It appears when i ordered them last two years ago, they shipped me two driver’s side parking lights. The new one is on order.
67 SWB First Build
Old 12-01-2023, 11:02 AM   #5
Kronald_70GMC
Kronald_70GMC's Avatar
Nice progress! I have been thinking about mounting my evaporator to the firewall too once I can afford to get it. Since I'm hoping to keep my firewall clean and not have bolts coming through it, I was doing research for options a while back. I believe that full custom fab has a bracket that mounts to the floor below the pinch weld and thus there is no need for drilling through the firewall. I found this info somewhere on this forum but I can't remember where specifically.
Kyle
1970 GMC "Project Splice"
2017 Yukon Denali (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 12-01-2023, 11:17 AM   #6
loudchevy
loudchevy's Avatar
Thanks for the company name for the kit. A quick Lougle search came up with this link
https://fullcustomfab.com/shop/ols/p...ket/v/GEN%20IV
I'm in the same boat with a shaved firewall and a future VA install. This bracket looks promising when you don't have the VA unit for stud layout before painting everything.
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 12-01-2023, 11:24 AM   #7
Kronald_70GMC
My thoughts exactly. I don't really want to buy my VA kit just to figure out mounting then have it sit on the shelf for potentially years until I'm ready for it.
Kyle
IG: kyle_ronald
Old 12-09-2023, 03:49 PM   #8
Scurry67
Oh nice, i wish i would have known about that earlier. That’ll be my plan B. For the time being, i ended up fabricating my own little bracket based on what i saw someone else do here on the forum. If it ends up being a flop, i just may have to try that bracket.
67 SWB First Build
Old 12-09-2023, 04:05 PM   #9
Scurry67
I built the evaporator bracket out of some scrap sheet metal and some flat bar i had laying around. It’ll mount above the evaporator, on the cowl. I think it’ll work okay.
I also mounted the condenser on the core support. What a PIA it was to install with the grill already installed. It took some time, but i was able to drill the core support and route the lines. It’s slowly coming together.
67 SWB First Build
