Old 11-13-2023, 02:58 PM   #1
68williams
71 c2500 centerlink
Good afternoon all,
I have a 71 c2500 camper that I'm playing around with. When I got it the center link had been cut off at the gear box end.. so its pretty much useless.
I plan doing some type of front disk swap but not sure which way to go yet. I was looking at the 8 lug disk kit from CPP. My question is can I take everything from outer tie rod to outer tie rod, including the steering box from a 73+ c20 truck? I would just rebuild the control arms I have and swap in the newer ball joint.
Could I take center link and stuff from a 72 c10?
And yes I want to keep 8 lug, trying to build a type of tow rig.
Thanks all.
Last edited by LockDoc; 11-13-2023 at 07:17 PM. Reason: Removed WTB. Needs to be a Premium member to post WTB
68williams is offline   Reply With Quote
Old 11-13-2023, 03:14 PM   #2
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: 71 c2500 centerlink
1971 C20 should already have front disc brakes. First year for them.
1973-UP entire front suspension does fit the older trucks. I believe you have to elongate or drill a couple of holes in the frame, but it goes in.
20 and 30 series use larger diameter center links, so the 10 series unit is not recommended.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
1970cstblazer is online now   Reply With Quote
Old 11-13-2023, 03:25 PM   #3
68williams
Interesting? was told it was a 71. its just a frame that I'm building to swap under a different truck. Might be a 70 then. Thanks for the info, new to the c20 game.
Old 11-13-2023, 03:28 PM   #4
1970cstblazer
1967-70 was drum brake. Also, all of the steering joints were smaller than 1971-up.
Old 11-13-2023, 07:19 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
LockDoc
Leon
Old 11-13-2023, 07:42 PM   #6
68williams
LockDoc...thanks for the link.
Old 11-13-2023, 11:57 PM   #7
LockDoc
LockDoc's Avatar
No problem.
LockDoc
Leon
Old 11-14-2023, 01:12 AM   #8
Sheepdip
Sheepdip's Avatar
This was my experience, some of it might help you in sourcing parts.
https://67-72chevytrucks.com/vboard/...d.php?t=803011
Sheepdip is offline   Reply With Quote
