Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 10-25-2023, 07:31 PM   #1
aotte1
Gmc 351e big block v6
GMC 1966 351E big block V6 out of a suburban that had 4 speed. Dressed pretty much as it was removed. Ran good when removed, suburban was customized reason for removal. It has PS installed and dealer installed AC parts in box (date coded 12/65). Price $500, needs to go, local pick up. Trying to sell whole to some one who needs, other wise will strip for parts. More photos if needed. AC parts are in a box not installed, under dash type unit by Eaton.
Still editing
aotte1 is offline   Reply With Quote
Old 10-25-2023, 08:56 PM   #2
1960chevypanel
Re: Gmc 351e big block v6
Interested in PS including pulleys if you part out
1960chevypanel is offline   Reply With Quote
Old 11-04-2023, 10:23 AM   #3
55-72 GM trucks
Active Member
So, These are my questions
1) is the Y pipe in tact or cut?
2) is the air cleaner not with it?
3) is the 4 speed still attached and does it come with it or available separately?
55-72 GM trucks is offline   Reply With Quote
Old 11-27-2023, 05:24 PM   #4
AngryPirate
AngryPirate's Avatar
The gentleman that owns or runs https://www.olsonsgaskets.com/ (pretty much the only place I can find oil pan gaskets for the GMC v6) needs a donor engine to reverse engineer the rear seal gasket.
I'm guessing this engine is likely the same internally as the 305 (for his purposes) with the exception of the pistons/cylinders?
You may see him pop into the classifieds.
He saved my bacon because he has gaskets for our trucks.
AngryPirate is offline   Reply With Quote
Old 11-27-2023, 06:44 PM   #5
1960chevypanel
Where is he located?
Old 11-27-2023, 06:50 PM   #6
AngryPirate
looking on the website it seems it might be Port Orchard, WA , which I guess isn't close to where the engine might be.
Old 11-30-2023, 10:53 AM   #7
55-72 GM trucks
Active Member
probably gonna have to do a better job of answering questions if Aotte wants to sell anything on here
Old 12-09-2023, 09:36 AM   #8
55-72 GM trucks
Active Member
PM sent Aotte - call me
Old 12-09-2023, 10:05 PM   #9
Backpayne
I wish I could find one of these near SWMO.
Backpayne is offline   Reply With Quote
Old 12-10-2023, 11:40 PM   #10
aotte1
No y pipe, only manifold;
Air cleaner came w/engine, not sure origional.
No transmission.
I have lots going on currently, so may may be slow to respond, thanks for understanding.
Old 07-24-2024, 12:43 PM   #11
aotte1
Engine going to scraper soon.
Old 07-24-2024, 10:31 PM   #12
Backpayne
Damn. If I were closer...
Old 07-25-2024, 08:48 AM   #13
55-72 GM trucks
Active Member
Its so sad to see how the LS swapping and bagging has literally ruined the hobby by pushing out the desire to restore anything to how it came. I blame this modification over restoration mindset for killing interest in parts like your engine. I am broke after just buying the wife a car with all my expendable money but before it gets scrapped, find out what you think they'll pay over the scales and I'll pay that and I will come after it despite having two already and definitely not needing a third. I just can't let it go to scrap. 800 lb engine x Kentucky's 160 per ton scrap rate (engines and cars) gonna be about a $130 payday at the scales is my guess
Old 10-06-2024, 09:06 PM   #14
jmedero
jmedero's Avatar
-hey man in hope you still have this. I need a few partrs off of it. My cell is 850-293-7763 and I am in Pensacola FL. I need the ac bracket, power steering bracket and pump and the crank pully. Please call me or text me and I will be happy to work it out with you. Thanks
Juan
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 10-06-2024, 10:15 PM   #15
DPowers
One foot in front of the other
DPowers's Avatar
Juan
Almost for sure he still does. Ill text him to check the site.
DPowers is offline   Reply With Quote
Old 12-08-2024, 10:35 AM   #16
55-72 GM trucks
Active Member
Aotte ole buddy, I hope everything is OK with you and your family since we spoke a while back about me coming after the 351 engine. I see your PM box if full, and Dewayne Powers said he has your phone number and alleges he's shared my number with you via text, but seeing you not calling or texting makes me question whether Dewayne is telling me the truth or not. Dewayne says he won't send me your number so I can make arrangements to come after the engine, so I am kinda stuck until either you read this, or Dewayne does and sees he's preventing you from selling the engine, and realizes its OK to send it maybe. If you do read this, text or call 256 486 1988
There is another Member, Juan, South of me wanting the AC parts so I told him I'd go get the engine and send him what he wants. We are both kinda stuck since Dewayne is protecting your phone number for some weird reason. Maybe another member also has your contact info and will let me know.
