Mystery Headlight Clips
I am replacing the headlights on my 83 C20 Silverado with quad headlights. There are 4 ciips attached to each headlight retainer screw (16 total) and they are very rusty. Does anyone know the purpose of these clips? I don't see them on other 83 Silverados.
Re: Mystery Headlight Clips
Looks like the person used dash pad clips, bent drilled them. But I could be wrong.
![]() Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
No, they are not dash pad clips - much smaller. They are about 5/16" wide and about 1.5" long. They appear to serve no purpose, other than to create rust spots in the area. At first I thought they had something to do with the headlight retainer bracket, but the brackets have their own screw holes to secure them to the headlight buckets. Maybe they are for some sort of covering that snaps on over the headlights, but I don't know why anyone would need that. They have been on the truck since I bought it in 2002.
Or, maybe clips to hold on a full width bug screen with cutouts for the headlights and clips to hold the frame in place?
![]() Join Date: Jun 2009
These were for a wire type rock guard. The guards came in chrome or black
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
![]() Join Date: Mar 2003
had a set of them on my old K5...there pretty much useless. whenever something hit them, the guards would get smacked into your headlights, them clips were pretty janky and would allow the wire to pop out and hit your lights.
little hard to see them if you look close you can see the cross hatch on the lights |
Thanks for the information. I can see how they could be a problem. I would think a full cattle guard on the front would be a better idea.
I use them on my Cibie Z Beams and Hella H4s. 35+ years and no problems.
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
