Old 12-05-2023, 07:22 PM   #6
howzzzit
howzzzit's Avatar
Re: A/C switch connector oddity
Thanks. I gave the switch plug a good push as well as the brown wire on the switch. All started working. You're probably right about moving the brown on the ignition switch. I'll check that. The slow blinker issue on the right rear was a ground issue. Ran the 5/16 mounting screws in and out a couple of times. Good to go.
Thanks again DJ.
and the radio is on the radio tab in the fuse box.
howzzzit is offline   Reply With Quote
