Old 12-07-2023, 12:59 PM   #1
Just1randall
1966 C10 LB with '69 Small Block?
Hello,
Recently acquired a 66 long bed project truck. Seller had told me it had a 283.... I can do an oil change and not much else, so had no clue.
Now doing some research and getting some mixed results.
What might I have here?
ViIN stamp on front passenger side of engine =19Zxxxx (1969?... were 283's still being made?)
Other stamp to right of VIN=T0916HR (HR is for 350?)
Oil tube attached to manifold= not on 350s?
'Camel' humps at front of engine casting=350?
Pic should follow.
Thank you
Just1randall is offline   Reply With Quote
Old 12-07-2023, 01:51 PM   #2
geezer#99
geezer#99's Avatar
Re: 1966 C10 LB with '69 Small Block?
Looks like a 69 350 with a 283 2 barrel intake on it.
Old 12-07-2023, 02:36 PM   #3
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Originally Posted by geezer#99 View Post
looks like a 69 350 with a 283 2 barrel intake on it.
x2
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 12-07-2023, 03:06 PM   #4
ConradBSomething
x3
You might be the only person in history to have been told it was a 283 and got a 350 instead of the other way around.
ConradBSomething is offline   Reply With Quote
Old 12-07-2023, 03:27 PM   #5
geezer#99
geezer#99's Avatar
Here’s some more info to help identify it.
https://www.mortec.com/
Old 12-07-2023, 03:29 PM   #6
Just1randall
Okay, makes sense now... good for me then
I'll be looking for the correct parts, but for now, can I safely test engine with that manifold?
Thank you all!👍
Old 12-07-2023, 03:38 PM   #7
geezer#99
geezer#99's Avatar
Sure, run it.
Old 12-07-2023, 05:14 PM   #8
Just1randall
Okay, got it... thank you!
Old 12-07-2023, 05:33 PM   #9
geezer#99
geezer#99's Avatar
What carb do you have?
Old 12-07-2023, 06:41 PM   #10
Just1randall
Here it is.
Old 12-07-2023, 07:20 PM   #11
geezer#99
geezer#99's Avatar
Good carb.
Rochester 2 jet.
Easy to work on.
Old 12-07-2023, 07:47 PM   #12
dlbraly
dlbraly's Avatar
You can verify from the number off the block as well if you have not done so yet.
Take Care,
Dave
dlbraly is offline   Reply With Quote
Old 12-08-2023, 12:24 AM   #13
Just1randall
Good to hear. I'm hoping to get it buttoned and tested up soon . Ty so much
Old 12-08-2023, 12:41 AM   #14
geezer#99
geezer#99's Avatar
Was the motor run before you got it?
Old 12-08-2023, 12:51 AM   #15
Just1randall
According to seller engine ran. Been parked for about 10 yrs. He had left it at top dead center... and distributer did drop right in.
I just came back from having alternator tested, but it failed. So that's next.
Old 12-08-2023, 01:07 AM   #16
geezer#99
geezer#99's Avatar
Just because the distributor dropped right in doesn’t mean it’s timed right.
#1 is on tdc twice in the cycle. You need to be on tdc compression to start.
You should treat the motor like it’s fresh. Set it up to fire right away at 1500 rpm. You need lots of rpm to properly lube the cam and lifters. They get their lubrication from oil splash.
Keep us posted as you go along.
Old 12-08-2023, 01:35 AM   #17
Just1randall
I'll look into that. Ty!
Old 12-08-2023, 04:29 PM   #18
dlbraly
dlbraly's Avatar
Cool, you are on your way.
Dido - just initial timing until you can pop it off and set the timing while it is running.
Take Care,
Dave
Old 12-12-2023, 04:14 PM   #19
MikeN
MikeN's Avatar
I think those have to be 69 heads because they are drilled at both ends for accessory bolt holes, and I think in 69 the camel hump heads only came on 350's with 300hp or more. I think you have the foundation for a great engine there - it's curious that someone put a 2-bbl intake and carb on it.
MikeN is offline   Reply With Quote
Old 12-14-2023, 03:48 PM   #20
Wrenchbender Ret
Sounds like a great candidate for an aluminum manifold & q-jet carb. That little 2 barrel is a great carb but it is leaving many horses in the barn.
George
Wrenchbender Ret is online now   Reply With Quote
Old 12-14-2023, 04:08 PM   #21
Just1randall
Wow, okay... thank you for that info. I do plan on getting it properly built up at some point. Currently I'm working on making sure it starts up. I found I have a bad alternator, and missing the fan and pulley. Baby steps for now.😉
Ty again
Old 12-21-2023, 04:21 PM   #22
Wrenchbender Ret
You are missing the accel. pump rod on that carb. If you need one I probably have one at my friends shop but I dont get down there very often.
George
Old 12-22-2023, 05:45 PM   #23
Just1randall
Hi George, I had to look that up, and dis find it in box. I added pic here.
Thank you 👍
