Old 12-08-2023, 09:51 AM   #1
57FleetsideC4
Cooling Fan relay setup
Hi all, I have a new question 0n my LS 57 pickup project. I want to run the one 16" fan I am using with 2 speeds off of fan 1 and fan 2 from the PCM. It looks like typically there is a 2 fan 3 relay setup that runs the fans on low speed by running the fans on a series circuit. I want to run the same 3 relay system with a resistor instead of a fan to slow down the one 16" fan I will be using. Does this seem like it would work? Thank You Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054
57FleetsideC4 is offline   Reply With Quote
